Results 1 to 11 of 11
Thread: Wilwood brake kits
    Wilwood brake kits
    Hi everyone, who is running the front and rear wilwood kits? If so which caliper in the front are you running aero or fnsl6? Also is anyone running the 15" kit? Please post pics if possible. I'm looking into upgrading my 06 gmq brakes to the 14" kit and was thinking of the Aero fronts but wasn't sure what it would look like since the Aero calipers are much larger than the smaller bodied rear caliper kit.
    Thanks
    Toby
    Sent from my moto g(7) play using Tapatalk
    Jun 2012
    Grand Rapids
    Quote Originally Posted by tobiasg1995 View Post
    Thanks
    Toby
    Contact Todd at TCE fro Wilwood info
    #2941 300A
    4.10's, carbon clutches
    Marty O Tune
    Curless Cure
    Widened Wheels
    Dead Pedal
    Eaton Swapped
    Bar tender and maker of:
    Christmas in a cup
    One Legged Lesbian Kickboxer
    Cocka Two
    Jul 2002
    Marietta, GA
    The "Big Brake" kit Zack worked up is better than Wildwoods for Maintenance and last a lot longer. Was more impressed with it over 5 vehicles I drove with Wildwoods, all had short mileage before buildup on rotors. Had to redo rotors at less than 10K miles, some at less than 5K. "Big Brake" kit requires 18"or larger wheels.
    Bill
    03 Mercury Marauder, 300A
    SOLD
    2005 Lincoln Town Car, ADTR Supercharger, TCE Brake Lines, MO's Tune
    2022 Lincoln Aviator Reserve AWD
    Quote Originally Posted by Black Terror View Post
    That's good to know, thank you for the info. I'm running 19" gt500 wheels currently
    I'm running TCE's original Big Brake Upgrade for the Marauder (front). Still using the original pads & rotors. Never had a problem with either. Has pulled my a$$ out of the fire more than once.
    Thank you for this info. I've reached out to Todd and got some more info. I'm on the fence on which wilwood either the Aero or super lite
    Jun 2009
    Warsaw, Indiana
    I'm with fastblackmerc. I had the TCE 14 inch kit with 6-piston calipers professionally installed after seeing how easy it was to heat-fade the stock brakes. At the time, I had a 28 mile daily commute involving 7 stop lights where you had to go from 60 to 0. As it's true that I have a very heavy foot, occasionally I was going a little bit more than 60. You can just use your imagination. They are the best brakes on any car I have ever owned, bar none.
    Rotor buildup could be a function of the choice of pads. I am running Hawk HPS compound pads on all 4 corners and have not seen that problem to date, with about 45 K on the brake upgrade.
    Quote Originally Posted by SteelQualityMan View Post
    This is great info, I think this has made me solidify my choice. I'll definitely be doing Wilwood then it is just deciding on which caliper I want to go with.
    Thank you to everyone that has responded. Have a great weekend
    Toby
    Have anyone looked into doing the 2018 up mustang brakes or GT350 brakes on these cars. Since you have 19s, then go big... Most of us like to keep the oem wheels so we do the zack and jerry corvette brakes. I have wilwoods on one marauder, and baer on the other car,.. under oem wheels.
    May 2018
    Maryland
    I have a mockup that I've been working on to use 2008 GT500 rotor and offsets and any caliper from 2005 up. The 2005-2018 mustang calipers all use the same bolt pattern and mounting offset (with different hat offsets) with the exception of the radial mount GT350 stuff. I'll try to do a thread on it once I have the IRS done. Definitely requires a 19" wheel or bigger.
    Sep 2005
    APPLE VALLEY,CA
    I have the Zack Big brakes on both Marauders. Cost wise it is reasonable.
    I drive hard and the brakes don’t fade.
    I’ve also been able to replace the pads and not have to turn the rotors because they don’t warp. I use the Wagner Thermo quiets wish cost about $50 for fronts and $25 for rears. Very happy!!!
  1. Wilwood brake installation
    By mike P71 in forum Steering, Suspension & Brakes
    Last Post: 02-11-2012, 07:55 AM
  2. Wilwood brake installation
    By mike P71 in forum Community Discussion
    Last Post: 12-10-2011, 10:13 PM
  3. Rear Wilwood brake kit install question
    By mtenderenda in forum Steering, Suspension & Brakes
    Last Post: 07-27-2010, 03:09 PM
  4. Another Wilwood Brake Question...
    By Architect in forum Steering, Suspension & Brakes
    Last Post: 06-14-2010, 04:27 PM
  5. Wanted To Buy Wilwood Brake Setup
    By Drewstang in forum Marauder Parts/Misc. Wanted
    Last Post: 01-07-2010, 01:13 AM
