Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 35
Thread: Differential Clutches
  1. #16
    Dec 2018
    Albemarle,NC
    I agree about the friction modifier also... 75/140 & 1 bottle of friction modifier otherwise it will chatter.
  2. #17
    Mobil 1 with no modifier WILL chatter.
  3. #18
    Wisconsin
    I had same experience with Mobil 1 even though its supposed to not need FM.
    I changed to Royal Purple = quiet as a church mouse with no added FM.
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
  4. #19
    We put the Mobil1 in Joe’s and didn’t make it one block without horrible chatter. Next stop was Advance for modifier!
  5. #20
    Dec 2018
    Albemarle,NC
    Red Line with no modifier same experience 2 cars even though it claims you don't need
  6. #21
    Sep 2008
    B'lo, NY
    I used 75W140 Mobil 1 after soaking the new clutches in friction modifier for 3 days and it still chattered like a mofo. Good thing I have the Ford racing diff cover, was easy to add the modifier afterwards without making a mess.
    To do list:
  7. #22
    No noise with over 90K miles with 75W140 Mobile 1 and no friction modifier.
  8. #23
    Sep 2005
    APPLE VALLEY,CA
    The Eaton tru track says no friction modifier needed. We definitely used modifier. Just the sweet hum of the Eaton working properly.
  9. #24
    Feb 2006
    Rosemount, MN
    I dropped my Marauder off at a local shop and said I was fairly sure the pinion bearing was bad and to have them replace the differential clutches while they had the rear end apart. They called me and said the growling noise from the rear end was a bad left front wheel bearing. The noise changes under acceleration and deceleration. I would think if it was a bad left front wheel bearing, the noise would get worse when turning right which is doesn't. Anyone else seen something like this?
  10. #25
    Jun 2012
    Grand Rapids
    Usually we can get the noise to change on a front wheel bearing if we swerve from right to left... usually... not always though. Hey, If the shop was honest enough to tell you this instead of just charging you for a rear diff I'd say they can be trusted!
    #2941 300A
    4.10's, carbon clutches
    Marty O Tune
    Curless Cure
    Widened Wheels
    Dead Pedal
    Eaton Swapped
    Bar tender and maker of:
    Christmas in a cup
    One Legged Lesbian Kickboxer
    Cocka Two
  11. #26
    Quote Originally Posted by Curless View Post
    If the repair actually fixes the problem.
  12. #27
    Feb 2006
    Rosemount, MN
    The shop just called and want me to come and take a look at the rear end. I'm guessing they now don't think the growling sound is the left front wheel hub. I'm heading there during my lunch hour today. If it needs a total rebuild and is really expensive, does anyone have any less expensive options? Maybe an entire rear end that I can install myself. If I buy a new carrier, I'll still need the gears set which I can't do. Anyone have a used carrier and axles for sale? I have new carbon fiber clutches.
  13. #28
    Feb 2006
    Rosemount, MN
    Spider gears are shot. The S spring is shot. Ring and pinion are ok. Axles are border line. For a quick inexpensive fix, does anyone sell 28 spline spider gears and S spring. It's up on the hoist and the shop and I need to get these parts quick. If not, I believe it means a new 31 spline carrier and 31 spline axles? What else would I need? Any help would be appreciated.
  14. #29
    Feb 2006
    Rosemount, MN
    I found this, but $200 is a lot of money.
    https://lmr.com/item/LRS-4215A/86-04...ction-Lok-Will
  15. #30
    Dec 2018
    Albemarle,NC
    Those are incorrect the Marauder had it's own spider gears that have been long out of production.Still have the 56k mile unit out of my 04 can mail it ASAP.
  1. For Sale FRPP 31-spline traclok with Cobra Clutches
    By ctrlraven in forum Marauder-specific Parts for Sale
    Last Post: 03-15-2013, 09:10 PM
  2. Ford Racing Carbon Trac-Lok Clutches
    By tbone in forum Shop Talk
    Last Post: 11-03-2012, 05:39 PM
  3. rear end clutches
    By maineiac in forum Shop Talk
    Last Post: 10-10-2012, 06:50 AM
  4. Are my clutches toast?
    By russell072009 in forum Transmissions
    Last Post: 09-07-2010, 08:49 AM
  5. Rear Diff Clutches
    By guspech750 in forum Community Discussion
    Last Post: 03-28-2010, 12:15 PM
