Results 1 to 3 of 3
Thread: Newest engine swap option
    Sep 2019
    Florence Kentucky
    MaskedMarauder
    Current Rides
    2016 Ford Edge Sport AWD
    - Bronze Fire Metallic with custom pinstriping
    - 2.7L EcoBoost Twin Turbo V6
    - 21" Rims w/ Michelin Premier LTX 265/40R21 Tires
    2003 Marauder 300A Black (Build #1800 out of 7838)
    - Order Date: 5/2/2002
    - Build Date: 6/21/2002
    - First Sale Date: 1/11/2003
    - Second Sale Date: 9/9/2019
    Options
    - With Trunk Organizer
    - With Rear Spoiler
    - With 6-disc CD Changer
    Mods
    - K&N Drop-In Air Filter
    - JVC KW-M650BT w/ Back-Up Camera and iDataLink Maestro Steering Wheel Interface
    - Custom X-Pipe Crossover
    - Jones Exhaust Glasspack Mufflers
    - Jones Exhaust 3.5" x 22" Polished Stainless Steel Rolled Edge Non-Resonated Exhaust Tips
    Former Rides
    1990 Ford Tempo GLS
    1991 Ford Tempo GL
    1996 Ford Explorer XLT
    2002 Ford Explorer XLT
    2004 Lincoln LS V8
    2010 Lincoln MKS EcoBoost
    2014 Lincoln MKS EcoBoost
    Feb 2017
    New Orleans, LA
    The newer version of that engine in a few years will make an additional 150 hp and get better fuel economy.
    decipha @ EFIDynoTuning
    I'm a dyed-in-the-(blue) wool FORD guy....but I never understood FORD's penchant for putting complex, small CID, higher revving, overhead cam engines into their trucks.
    IMHO, the 4.6 and 5.4L V8s were a waste of money and didn't do much.... unless you put a blower on them. Changing the '2 piece' spark plugs was fun too!
    The Coyote 5.0 is a nice engine, but I don't need 4 cams and a lot of other complex stuff in my pick-up.
    If I'm not buying the $10,000 option Diesel engine in a truck, ... then I want a simple, big cube, pushrod V8 with stump pulling low rpm TORQUE.
    They obviously wised up with the 7.3L Godzilla engine!
    It'll be fun to see what engine shops will be able to do with this beast.
  1. The infamous M335 engine option
    By Invective in forum The Lounge
    Last Post: 04-06-2020, 07:55 AM
  2. Engine Swap
    By saxman in forum Shop Talk
    Last Post: 02-09-2011, 06:51 PM
  3. New FRPP Coyote 5.0 Engine Option?
    By dohc324ci in forum The Lounge
    Last Post: 03-26-2010, 02:37 PM
  4. Engine swap
    By jdenning002 in forum Shop Talk
    Last Post: 11-29-2009, 02:17 PM
  5. engine swap.....
    By 4drpower in forum Shop Talk
    Last Post: 11-02-2009, 07:21 AM
