Results 1 to 15 of 18
Thread: Door lock question
    Sep 2019
    Florence Kentucky
    Door lock question
    So the driver's door on my 03 won't lock when I push the lock button on the panel or by the fob and keypad. I have to physically push down the lock lever to get it to lock. It will unlock just fine. All other doors lock fine. Is this an issue with the actuator or is there another culprit?
    MaskedMarauder
    Current Rides
    2016 Ford Edge Sport AWD
    - Bronze Fire Metallic with custom pinstriping
    - 2.7L EcoBoost Twin Turbo V6
    - 21" Rims w/ Michelin Premier LTX 265/40R21 Tires
    2003 Marauder 300A Black (Build #1800 out of 7838)
    - Order Date: 5/2/2002
    - Build Date: 6/21/2002
    - First Sale Date: 1/11/2003
    - Second Sale Date: 9/9/2019
    Options
    - With Trunk Organizer
    - With Rear Spoiler
    - With 6-disc CD Changer
    Mods
    - K&N Drop-In Air Filter
    - JVC KW-M650BT w/ Back-Up Camera and iDataLink Maestro Steering Wheel Interface
    - Custom X-Pipe Crossover
    - Jones Exhaust Glasspack Mufflers
    - Jones Exhaust 3.5" x 22" Polished Stainless Steel Rolled Edge Non-Resonated Exhaust Tips
    Former Rides
    1990 Ford Tempo GLS
    1991 Ford Tempo GL
    1996 Ford Explorer XLT
    2002 Ford Explorer XLT
    2004 Lincoln LS V8
    2010 Lincoln MKS EcoBoost
    2014 Lincoln MKS EcoBoost
    Apr 2010
    South Florida
    Usually the actuator.
    Is the lock knob hard to operate?
    Do you hear the actuator trying to work?
    Jan 2018
    Califon NJ
    Mine is doing the exact same thing. Unlocks correctly, have to manually lock the driver's door with the key.
    I bought a new actuator and haven't had time to put it in yet.
    2003 300a Trilogy #? 4.10s
    2000 Excursion limited v10
    1997 F350 7.3 5spd 4x4 (service truck)
    1992 Taurus SHO vortec SC 5spd
    1971 GMC 2500 pickup
    1971 GMC 2500 suburban 4x4
    1967 Camaro (basket case)
    Sep 2019
    Florence Kentucky
    No, the knob is not hard to work at all. The actuator works when unlocking, but not when locking. It doesn't make a sound when you try to lock it electronically.
    MaskedMarauder
    Current Rides
    Options
    - With Rear Spoiler
    Mods
    Former Rides
    1990 Ford Tempo GLS
    1991 Ford Tempo GL
    2004 Lincoln LS V8
    Long Island, NY
    Keep us posted.
    My Marauder does the same at times.
    Thanks
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    Mercury All Weather Mats
    1973 Oldsmobile Toronado
    2012 Kia Sedona Van
    2008 Corvette Convertible
    2021 Prius Prime Limited
    Member # 440
    ----- John
    Quote Originally Posted by MaskedMarauder View Post
    Pull the door panel and see if your getting power to the actuator.
    Have a spare actuator just in case you need to replace it.
    You can usually just pop the old actuator out of the bracket and pop the new one in. If you have to replace the bracket, use a 14-20 stainless steel bolt, washer and nylock nut (nut on the inside).
    Sep 2019
    Florence Kentucky
    So if it will unlock using the fob, switch, and key panel, wouldn't that mean that I'm getting power to the actuator and that it's just going bad?
    MaskedMarauder
    Current Rides
    Options
    - With Rear Spoiler
    Mods
    Former Rides
    1990 Ford Tempo GLS
    1991 Ford Tempo GL
    2004 Lincoln LS V8
    May 2009
    Moreau Island
    Does it lock when you put it in drive?
    No.
    But it does lock when I press the brake pedal the first time!
    May 2009
    Moreau Island
    No.
    I always thought it was a 'put it in gear' thing. Now I'll have to test your take on it. Nice day tomorrow so might be a good chance to go for a toot.
    Sep 2019
    Florence Kentucky
    Nope. All other doors do. Like I said, it will unlock via power, but it won't lock via power.
    MaskedMarauder
    Current Rides
    Options
    - With Rear Spoiler
    Mods
    Former Rides
    1990 Ford Tempo GLS
    1991 Ford Tempo GL
    2004 Lincoln LS V8
    Wisconsin
    Odds are its the actuator, they are known to fail (had to replace both on my 99 F150). Pull the panel, put a test light on the plug and hit unlock. If the TL lights up then the actuator is bad. Simple cheap repair.
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
    Jan 2008
    Shell Beach
    I tested things out in my Marauder and all doors lock when I put it in gear. No locking happens by applying (releasing) the brakes.
    Silver Birch Society
    "I hear and I Forget
    I see and I Remember
    I do and I Understand"
    Quote Originally Posted by Ms. Denmark View Post
    Since my wiring was obviously modified anything could be “off”. But I am curious now.. The next time you are in a safe place to do so, could you start it in neutral with no brake and drop it in drive? Just roll on out 10’ or so and touch the brake.
    When I start my car I’m in a garage and I don’t use the brake. I just start it up, pop the parking brake, put it in 1st, and roll on out. It’s not till the end of my driveway until I apply the brakes and that’s when mine always lock.
    The only negative i can really think of on this swap is having no way for the doors to know when to unlock without the use of the door switch. Not much of a real world issue, more so OCD...
    If you could that’d be swell!
  1. Door Lock Switch question ?
    By fordnut02 in forum Interior Electrical/Electronics
    Last Post: 12-06-2015, 06:52 PM
  2. door lock pins
    By L.Mark in forum Shop Talk
    Last Post: 10-09-2013, 01:02 PM
  3. Passenger door window/door lock problem
    By blackcobra95 in forum Shop Talk
    Last Post: 08-02-2011, 06:54 AM
  4. door lock
    By bugsyc in forum Shop Talk
    Last Post: 04-27-2011, 09:00 AM
  5. Door lock
    By 94_302 in forum Shop Talk
    Last Post: 09-19-2008, 03:38 AM
