Cross over tube for DOHC
For Sale:
Excellent condition COT/Cross Over Tube.
Very little corrosion anywhere on the 2 parts.
All welds are in great shape as well as the mounting tabs.
OEM black powdercoat is in very good condition
The burp plug even unscrews and comes out!
$300 plus shipping to lower 48 states.
$275 Black Friday Special plus shipping in CONUS
