Results 1 to 13 of 13
Thread: Right rear caliper seizing
    May 2009
    Moreau Island
    Went for a long toot yesterday just for the heck of it. Car worked fine all day, mostly back roads, till I needed to stop and back up to read some guys rant plywood sign on the evils of Trump. When I hit the brake this time I got the positive whiff of burning brake pads. Lots of stopping previously in the day with no malodorous air of brake. Drove home which was at that point only a couple of slow miles. Went around the car feeling the wheels to see which one was hot and of course the right rear was the culprit. Every Ford product I've ever owned has had the right rear caliper freeze up, Why? I imagine the slides are pitted and starting to rust so a new caliper is in my future. Might just get all four and G2 them. Anyone have any idea what goes wrong with calipers that they seize suddenly? What kind of preventive maintenance do you guys do to keep the brakes working like new?
    Thanks for any advice.
    PS: Which piston is better, metal or phenolic?
    I just finished rebuilding my rears for the heck of it. Cheaper, and no core to return. All I can say is plenty of anti seize!
    Lehigh Valley, PA
    Doesn't your car sit a lot and outside? I know its low mile, part of that could contribute to a caliper sticking.
    Factory calipers have phenolic pistons, either choice realistically will work fine.
    2063/3214
    5377/7838
    I’ve also heard of the parking brake shoe hardware coming apart inside.
    Jan 2018
    Califon NJ
    9 out of 10 times the pads are frozen in the slides due to rust buildup, especially when things sit. When installing the pads I do a dry test fit with the pads and shims in the bracket to make sure they slide freely. Quite regularly new pads aren't stamped perfectly or have excess paint on the ears. After any necessary trimming during the dry run liberally apply a quality brake grease under and on top of the shims.
    Regarding calipers seizing it seems to happen more often these days. I haven't really investigated the causes, generally assumed there was corrosion inside the caliper preventing the piston from sliding back in. The braking system generates lots of pressure to push the pistons out while the rotor generates minimal pressure to go back in.
    Also fairly common these days is brake hose failure. The rubber hose swells inside causing a restriction and effectively turning into a check valve.
    2003 300a Trilogy #? 4.10s
    2000 Excursion limited v10
    1997 F350 7.3 5spd 4x4 (service truck)
    1992 Taurus SHO vortec SC 5spd
    1971 GMC 2500 pickup
    1971 GMC 2500 suburban 4x4
    1967 Camaro (basket case)
    May 2009
    Moreau Island
    I wouldn't be surprised if it was a rust issue. Just seems weird it always seems to be the right rear, and why would it suddenly seize after driving around for a couple hours?
    Probably going to get some new ones and G2 them if I can figure out what color I want.
    Oct 2004
    Multiple things to check when signs of brake caliper failure. Always good maintenance.
    1)Flush brake fluid every two years. Use quality dot 3 brake fluid.
    2) Emergency brake. See if operable & free.
    3) Pinched or collapsed brake line. Check brake fluid flows freely.
    4) Frozen calipers pistons. Both pistons move freely & even pad wear.
    5) Pads to tight pitted bent or gunked up slides with dirt sand.
    Jan 2018
    Califon NJ
    Coincidentally I was helping a friend with his truck yesterday. As luck would have it, the right rear brakes were hanging up and wore the inside pad to the metal.
    2002 F250, the brakes were supposedly about a year old.
    One of the caliper pins was rusted absolutely solid in the caliper bracket. There was no visible issues with the rubber boot. Was unable to get the pin out with heat and penetrating oil. Replaced the bracket, pins and boots in addition to the pads and rotors.
    Caliper pin /slider https://imgur.com/gallery/xQOanzs
    Wisconsin
    G2 them? what's that mean? Never heard it before.
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
    G2 paint
    Jun 2008
    Of the Panthers I’ve owned that have had rust, they have all rusted worse on the passenger side near the rear wheels than the driver’s side. No idea why. But maybe that phenomenon is leading to that caliper failing?
    (probably not, idunno)
    In salting states the melted and unbroken chunks all collect on the side of the road. That has always been my theory.
    Wisconsin
    G2 paint
    Thanks Bob! Had me going, thought I missed some sort of brake mod!
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    JL 6.5 SubWoofer
    Mo's Dyno Tune
  1. Wanted To Buy Rear caliper brackets
    By Mercury in forum Marauder Parts/Misc. Wanted
    Last Post: 01-04-2013, 03:54 PM
  2. Wanted To Buy Rear brake caliper bracket/mounts
    By BigM460 in forum Marauder Parts/Misc. Wanted
    Last Post: 10-09-2012, 04:46 PM
  3. Wanted To Buy Rear brake caliper bracket/mounts. Crown vic, grand marquis
    By BigM460 in forum Other Parts/Misc. Wanted
    Last Post: 10-09-2012, 04:45 PM
  4. How do you know if rear brake caliper is broke ?
    By Ktorres1 in forum Steering, Suspension & Brakes
    Last Post: 04-06-2011, 06:04 AM
  5. Rear Caliper Seal kit
    By cougar9150 in forum Steering, Suspension & Brakes
    Last Post: 06-19-2010, 10:42 AM
