Results 1 to 11 of 11
Thread: Air Bag Light - 2016 Ford Explorer
    Feb 2006
    Rosemount, MN
    The air bag light on my wife's 2016 Ford Explorer Sport is on. I checked the connections under the seats to make sure nothing was disconnected. Anyone run into anything similar?
    Thanks,
    Curt
    All the time, the most common failure for that is the driver side seat belt buckle, a code reader will be needed to determine that though.
    Trilogy # 192 / T.S. 0012
    Iirc, there was a tsb on that from Ford, not warrantable, unless your super tight with your deal and/or have super low miles on the vehicle.
    Feb 2006
    Rosemount, MN
    I'm guessing my simple code reader will not work to identify the problem? I watched a couple YouTube videos where the guy had this fancy touch screen device.
    No clue, I have a IDS at my disposal. I would suggest ForScan and the inexpensive interface they suggest, or, maybe a local auto parts store can read srs codes
    Feb 2006
    Rosemount, MN
    Now the air bag light is off. Something must have triggered it and I'm guessing a certain number of key cycles reset the light?
    I fixed one of those a couple months ago in the ‘15 take home that I have, was intermittent, had a code for the buckle, changed it and haven’t had it come back on. The biggest issue is when the light is on, the srs is disabled, meaning if your in a collision, no airbags or seatbelt pretensioners will work.
    Feb 2006
    Rosemount, MN
    Called O'Reilly Auto and they said their scanner will identify where the issue is located. Next time it comes on, I'll bring it there right away.
    Thank you everyone for your help on this.
    Wisconsin
    The code may be held in memory. If you're driving by, swing in and have them check it.
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
    It generally sets a hard code, it will be in there for 200 key cycles iirc
    Feb 2006
    Rosemount, MN
    Thanks for the info. I'll do that on Thirsday.
  1. 2016 Ford Explorer A/C
    By crouse in forum The Lounge
    Last Post: 06-04-2020, 02:14 PM
  2. Replies: 2
    Last Post: 05-12-2020, 06:19 PM
  3. 2016 Ford Explorer Sport
    Last Post: 03-01-2019, 11:05 AM
  4. TT Ford Explorer
    By ChiTownMaraud3r in forum The Lounge
    Last Post: 03-15-2013, 08:26 PM
  5. 2011 Ford Explorer
    By QWK SVT in forum Photography Forum
    Last Post: 08-06-2011, 07:37 PM
