Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 64
Thread: 03 MARAUDER OVERHEATING
  1. #16
    Oct 2020
    texas
    yes I believe so....however the lower hose does not seem to be pressurized and is never as hot as the other hoses...I believe thats normal though..I could be wrong. Is there a possibility that the fan could be bad? It spins when the temp rises..but I read somewhere that that doesnt mean its doing its job.
  2. #17
    It can take more than one burping procedure.. Are you following the steps in the stickied post here in the forum? Replace the cap in overflow tank..(degaussing) if it overheats when accelerating, seems like air pocket preventing flow to me. Is stat installed in correct position?
  3. #18
    Aug 2010
    Southern NJ - Exit 4
    It looks like your Murray thermostat is identified as a Marauder tstat but a number of posts and acknowledgements identify this tstat as being correct
    Motorcraft RT1085
    You may want to try another tstat (the Murray is bad?).
    Sent from my Pixel 3a XL using Tapatalk
  4. #19
    Aug 2010
    Also I'm sure that you've seen this but just in case, it's worth reposting
    http://www.reischeperformance.com/refill.html
  5. #20
    Oct 2020
    texas
    Thanks, I looked for the RT1085 but cant find it. I ended up taking to the dealership this morning, because she is my DD and i cant go long without her. I'll post the results of the Diag
  6. #21
    Aug 2017
    Texas
    Try running without the thermostat I've done that before. and i always back feel mine from the cross over tube. slowly fill it. I never have had to burp it when I do it that way. If it still overheats without a thermostat and your radiator fan is working. I would look for a head gasket test kit.
  7. #22
    Sep 2005
    APPLE VALLEY,CA
    The correct thermostat is Genuine OEM Ford Thermostat F5OY8575A RT1110 Motorcraft
  8. #23
    Wisconsin
    Quote Originally Posted by dbrown View Post
    New Motorcraft number is 7L3Z-8575-D
    https://www.tascaparts.com/oem-parts...bC12OC1nYXM%3D
    https://www.amazon.com/Ford-7L3Z-857...2800059&sr=8-1
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
  9. #24
    May 2009
    Moreau Island
    If the car ran fine before you worked on it the problem is most likely related to something you did. IIRC the Marauder thermostat has a hole it it to allow coolant to flow all the time to some degree. Did the replacement T-stat have that hole? If it did it sounds like there is still air in the system somewhere.
  10. #25
    Wisconsin
    The hole is to allow air thu it when filling system. This is why when installing in a vertical application the hole (or sometimes a little dangely valve) has to be in the 12 o'clock position.
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    JL 6.5 SubWoofer
    Mo's Dyno Tune
  11. #26
    "degaussing tank"? Huh?
    So just guessing, you never verified if your cap was holding pressure? As hard as it is to believe, this system requires pressure for the cooling system to work, no pressure, no cooling, but it’s at the dealer, they’ll figure it out for you.
    Trilogy # 192 / T.S. 0012
  12. #27
    Nov 2006
    Union City, CA
    Does it have the bypass? Should be a hole near the spring.
    1988 LTD Crown Victoria S
  13. #28
    Nov 2006
    Union City, CA
    "Beware of aftermarket companies who sell the same thermostat for all Ford modular engines. Those units are designed for the 2V SOHC engine and, if installed in the improper housing, will be unable to shut off the bypass- allowing hot coolant to recirculate back into the engine at all times, reducing the efficiency of your cooling system. "
  14. #29
    Oct 2020
    texas
    Thanks for the comments guys. Ill break down everything as it happened.
    Left work Friday- car overheated
    Sunday- replaced thermostat with a Murray t-stat shown in my earlier post= car still overheating; replaced water pump= car still overheating; replaced driver side coolant temp sensor= car still overheating; burped the car 700 times=car still overheating; replaced reservoir cap (just to be sure) = CAR STILL OVERHEATING;
    Monday- bought lift ramps to get the front end higher and burped it 100 times= CAR STILL OVERHEATING
    Thursday= DEALERSHIP/ STEALERSHIP
    Still waiting for diagnostic
  15. #30
    Sep 2005
    APPLE VALLEY,CA
    I think it’s your thermostat.
    You have the wrong one. Only use a Motorctaft in
  1. Replies: 28
    Last Post: 01-25-2021, 11:36 AM
  2. 2003 Mercury Marauder Overheating
    By jfernandezs in forum The Classic Lounge
    Last Post: 04-14-2020, 04:50 AM
  3. Marauder overheating
    By 88LTDCV351 in forum Shop Talk
    Last Post: 04-01-2019, 01:56 AM
  4. Overheating marauder
    By Cabotwick in forum Shop Talk
    Last Post: 09-06-2016, 11:07 AM
  5. Replies: 5
    Last Post: 05-22-2013, 01:37 AM
