Results 1 to 6 of 6
Thread: Eaton pulley combo for pump gas
    Jan 2016
    South NJ
    I built engine with 4032 flat top pistons, roadrunner rods and the stock crank.
    My eaton came with a 2.76 inch pulley on it, which I do not plan to use. I bought a -2 lb lower pulley with the intent of finding a 3.4 inch upper pulley to net around the stock boost level. I'm having trouble finding a 3.4 inch pulley now, so I'm looking at other options. Anyone out there having success with a 3.1 inch pulley and -2 lb pulley, running 93 pump gas? I have a calculated 10.7:1 static compression.
    I think a 3.1 and -2 lower equates to about a 3.4 upper and the stock lower pulley. Open to all your experiences to ensure I put the right pulley on this.
    Sent from my SM-G930U using Tapatalk
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    14.33 @ 96.82 with OLD engine
    6R80 swap in progress
    1968 Chevelle
    NA/Pump Gas 10.4 @ 128 mph
    416/4L85E LSA Supercharged build underway
    Sep 2008
    B'lo, NY
    Probably wont help but just FYI, Im running a +2lb lower and stock 3.6 upper with a Stiegemeyer Stage 6 port and Stainless Works long tubes and it makes ~11psi with a stock motor.
    To do list:
    Jan 2016
    South NJ
    Quote Originally Posted by dmjarosz View Post
    Great info. Are you running pump gas?
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    1968 Chevelle
    Oct 2005
    West 'burbs Chicago
    3.1 upper and stock lower yields about 11psi here, was on factory compression, but now will run a bit less after rebuild.
    '21 F150 XLT 5.0 Sport
    '18 Chevy Malibu Redline
    '10 Harley Ultra Limited
    '08 Kawasaki ZX6R
    '03 Grand Marquis(sold)
    Jan 2016
    South NJ
    Quote Originally Posted by ChiTownMaraud3r View Post
    Nice. I think a 3.2 sounds about right for me then considering I have the under drive lower. Trying to keep it around 8 psi
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    1968 Chevelle
    93 is good to around 19#s I’ve been told. I flirt with 19-21 on 93 almost every week it’s driven, but that’s also on a lower compression Cobra block.
    I’d be more worried about over spinning that roots with a 2.anything upper. My old Trilogy set up was first stock pulleys (yawn) then a 3.2 upper, only 2 psi added but definitely better, finally a 2.8 upper and +4 lower on 93. I pegged my gauge so I upgraded to a 0-30 and saw a consistent 20#s of heat being made and only made 461 over the 3.2/stock lower that made 445 if I recall..
    I’ve never heard of a -2 lower?
  1. THE MARAUDER CENTRIFUGAL PULLEY /BOOST COMBO THREAD
    By Jeronimojc in forum Power Adders
    Last Post: 04-30-2017, 01:13 PM
  2. Pulley combo with ported eaton and long tubes
    By dmjarosz in forum Power Adders
    Last Post: 04-04-2015, 12:51 PM
  3. Wanted To Buy Eaton swap: crank hub adapter, 2# pulley, fuel pump, intercooler
    By chief455 in forum Marauder Parts/Misc. Wanted
    Last Post: 02-22-2014, 08:45 AM
  4. Water Pump and Pulley
    By MrHall1 in forum Shop Talk
    Last Post: 05-13-2013, 10:06 AM
  5. Replies: 26
    Last Post: 05-09-2012, 05:34 PM
