Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 39
Thread: Poor Fuel Economy
  1. #16
    Winston Salem, NC
    when you get that tune...lookout! the "Partay" will begin...it's a better experience in EVERY manner!
    2003 300A
    Eaton Swapped by Curless
    Brake Upgrade
    Mo's Tune
    JLT Intake
    Addco Sway Bars
    ADTR Coil Over Suspension
    SW Headers and Exhaust
    Accessories By FastBlackMerc
    4.10 Gears
    Aeroforce Gauges
    Pantherlights Headlamps
  2. #17
    May 2020
    Georgia
    Quote Originally Posted by Peace2Peep View Post
    How difference is the fuel economy with the tune or is it basically negligible? I assume I'll lose out on maybe 1 or 2 MPG but it's a far cry from the 10 MPG I was getting with that godawful Reinhart tune.
    2003 300B Mercury Marauder
    Built 01/22/03
    Purchased 01/29/20
    68,xxx miles
    July 12, 2023 - 68,203 Miles - RIP original engine
    October 31, 2023 - Rebuilt engine installed
    Modifications/Stuff I have done on the car:
    Engine:
    rebuilt stock; slightly overbore. Original 68k mile heads, new OEM Ford performance timing kit, Terminator Cobra Oil Pump, Billet Steel oil pump gears, ARP head studs, main cap studs, and side bolts. The latter ARP stuff for future endeavors.
    Transmission:
    Thor 2800-3000 Stall Converter
    Suspension:
    ADTR Front + Rear Sway Bars
    Metco Billet Watts Link
    Metco Billet Rear Control Arms
    Cosmetic:
    1998-2003 Amber tail lamp conversion - Painted and smoked to near-OEM spec.
    HID Projector Headlamp Retrofit
    OEM Mercury Mountaineer Hitch Cover
    Front in-channel rain guards
    Other Stuff:
    4-pin trailer harness
    Class III Tow Hitch
    Cadillac 4-note horns
    Hayden 679 Transmission Cooler
    Obligatory Marty Tune
  3. #18
    Wisconsin
    Quote Originally Posted by baloneyhomie View Post
    It will go up from what you currently have.
    OEM with Lidio tune = 22mpg
    Add 410s = 20.5mpg (and well worth it!!)
    Add Trilogy with canned Trilogy tune at 350 RWHP = 24mpg
    Add Martyo dyno tune, 17* timing, 409 RWHP = 17mpg
    Add my custom designed exhaust fabbed by Red at Martyo's with new dyno tune, 14* timing, 436 RWHP = 20mpg (16* timing shot it to 463 RWHP so Jeff had to dial it back as still OEM block internals)
    So, ya, you can do better.
    Good luck!
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
  4. #19
    Winston Salem, NC
    Not totally sure in your specific case, but with the 4.10's and the tune you should be even or just 1-2 loss from normal. Normal for me was 21mpg
    2003 300A
    Brake Upgrade
    Mo's Tune
    JLT Intake
    Addco Sway Bars
    4.10 Gears
    Aeroforce Gauges
  5. #20
    May 2006
    Seattle, WA
    Complaining about mpg with a Marauder is silly. We all know what we were getting into when we purchased this vehicle. We made our bed, we'll sleep in it.
    However... complaining about mpg with a valid reason is completely different. As GDMJOE said.. It's an anomaly.
    Even with a crappy supercharger or elite amp/sound system, No Marauder should be under 17 mpg. Are the fuel lines clear? Tank empty of debris? Saw another thread (not here on this forum and not a Marauder) that some guy got a leaf or something stuck in the tank and covered the flow from the fuel pump to the engine.
    Now, how likely is that on your Marauder? I would venture slim to none. But can't rule out the outliers. One thing I've learned with ownership of this car is that SHE'LL fool you. I hope you figure out your gremlin
    Also yes go to Marty for all things modification.
  6. #21
    10 MPG average is horrible unless you drive WOT a majority of the time.
    If not, the exhaust fumes would be awful at idle.
  7. #22
    Quote Originally Posted by Mebot View Post
    Step up to 80# injectors..!
    This biotch can DRINK!
  8. #23
    May 2020
    Georgia
    Hey y'all, sorry it's been so long. I totally forget about this thread, but it's been several months that I've had my Marty tune and I absolutely love it. I manage 15 mpg in my area in most of my tanks, although I still get as low as 10 sometimes, but I suspect that's just from the geography.
    All is good, and thank y'all for your suggestion of getting a Marty tune. He does good work, and my car feels so much faster.
    Thinking of maybe sticking some 4.10s in it if the fuel eco wouldn't suffer too much. Thoughts?
    Built 01/22/03
    Purchased 01/29/20
    68,xxx miles
    Engine:
    Transmission:
    Suspension:
    Cosmetic:
    Other Stuff:
    Class III Tow Hitch
  9. #24
    You'll lose maybe 1 or 2 MPG. Well worth the 4.10's.
  10. #25
    May 2009
    Moreau Island
    If you are really getting 15 mpg's or lower in regular driving you still have a problem. Your profile says your MM is NA. I'd take the car to Mo's and have them go over it to find out why your mpg's are so bad. You should be getting low to mid 20mpg's.
  11. #26
    May 2020
    Georgia
    It's effectively stock. I assumed 15 was normal for NA but I guess not. My old '09 SAP CVPI with 3.27s managed a solid 20-25 in my town.
    Luckily I live about an hour away from Mo's; I assume I just gotta give his shop the call and let him know what's up?
    Now I'm getting a bit worried, considering how good of shape this particular car is in
    Built 01/22/03
    Purchased 01/29/20
    68,xxx miles
    Engine:
    Transmission:
    Suspension:
    Cosmetic:
    Other Stuff:
    Class III Tow Hitch
  12. #27
    May 2020
    Georgia
    I'll put them on the list, in that case.
    Built 01/22/03
    Purchased 01/29/20
    68,xxx miles
    Engine:
    Transmission:
    Suspension:
    Cosmetic:
    Other Stuff:
    Class III Tow Hitch
  13. #28
    Jun 2008
    Waukesha, WI
    My first Marauder was stock when I bought it. My first mod was 4.10's and a tune. Best bang for the buck!
  14. #29
    How are you calculating fuel mileage? Are your rear tires factory size?
  15. #30
    May 2020
    Georgia
    Dividing the miles driven on the trip odometer (reset it every tank) by the gas pumped into the car next time I fill up. I got 12ish MPG on my last tank. Tires are factory size.
    Built 01/22/03
    Purchased 01/29/20
    68,xxx miles
    Engine:
    Transmission:
    Suspension:
    Cosmetic:
    Other Stuff:
    Class III Tow Hitch
  1. different fuel makin huge fuel economy difference?
    By montyd in forum Community Discussion
    Last Post: 08-31-2012, 07:24 PM
  2. exceptions for fuel economy
    By Bradley G in forum The Lounge
    Last Post: 07-01-2011, 09:07 PM
  3. Fuel Economy
    By Aren Jay in forum Community Discussion
    Last Post: 09-04-2007, 07:42 PM
  4. Pro Guard increases fuel economy
    By Mike Poore in forum Community Discussion
    Last Post: 10-21-2005, 06:12 AM
  5. Mods for better fuel economy!
    Last Post: 02-26-2004, 04:52 AM
