Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Thread: New Crate Engine from FORD
  1. #16
    Brian Wolfe (Retired FORD Engineer & Drag Racer)
    is getting 790 HP.....N/A out of the Godzilla Engine
    and only 1450 HP with a Whipple 3.0L Blower.....
    https://www.youtube.com/watch?v=bbtPN37LvmU
    Imagine that beast in a Marauder!
    ...and all the extra room under the hood once the 4.6 DOHC is replaced with a 7.3L pushrod Big Block.
  2. #17
    Sep 2008
    USA
    Team z put a Godzilla in a fox body already lol
    Ex Panther Owner
  3. #18
    Sounds like there wasn’t much Godzilla about it besides block, crank, and timing chains!
  4. #19
    Blog Entries
    2
    So Low where you at?
  5. #20
    Jun 2007
    Whitehall, PA
    here is one going in a CV. https://youtu.be/2HOs83ePejU
    2003 DBP/LF - # 36 (Sold)
    2003 DBP/LF - # 205 (Sold)
    2004 Black - Trilogy #43
    2003 Black - shitbox
  6. #21
    Sep 2005
    APPLE VALLEY,CA
    Ford Performance is now testing a twin turbo Godzilla engine. To me, a supercharger would make more sense.
  7. #22
    Blog Entries
    2
    One problem with turbo chargers are the heat that they radiate, possibly affecting various parts under the hood. This can be mitigated by using insulation or by mounting them remotely
  8. #23
    Turbos would make more sense on the 7.3L Godzilla because it already has gobs of low end torque. With turbos, the midrange and top end pull would be sick.
    Although a supercharged Godzilla WOULD make an awesome tire annihilator!
  9. #24
    Sep 2005
    APPLE VALLEY,CA
    Current SC Godzilla’s can make over 1000 HP. The block is amazing!
    A modified engine did this:
    With the help of Whipple Superchargers, Brian Wolfe got the massive pushrod engine to make 1450 hp and 1030 lb-ft of torque.
    Don’t get me wrong. A twin turbo has made more than 1000HP also.
    I think the main point for Ford is that this is an alternative to the $10,000 Diesel option on the F250. It also is more Smog friendly than the Diesel to help pass future Smog rules.
  1. Replies: 2
    Last Post: 04-21-2019, 11:47 PM
  2. 97 Grand Marquis With Crate Engine
    By FakTorThis in forum Shop Talk
    Last Post: 10-08-2008, 04:37 PM
  3. 4.6 Crate Engine
    By bryanthomas in forum Community Discussion
    Last Post: 04-23-2006, 06:52 PM
  4. Crate engine?
    By Motorhead350 in forum The Classic Lounge
    Last Post: 12-23-2005, 09:13 PM
  5. Ford Racing Technologies 5.0L Cammer Crate Engine
    By Constable in forum The Lounge
    Last Post: 10-29-2003, 06:29 PM
