Eaton swap battery /alternator cable pictures
How are you guys routing your battery cables? Alternator wires? What gauge wire are you using?
I was thinking of cutting off the original ground from the timing cover and grounding that to the frame on the passenger side. Then I was going to run a short but thicker cable from the battery direct to the frame on the driver's side.
For the positive wire, I was going to run it across the top of the header panel and solder splice it into the existing cable going to the starter.
Pictures are worth 1000 words if you got em.
Thanks bros.
2003 Marauder 300A
#2928 of 7838
Build date: 8/6/02
Ship date: 5/28/03
14.33 @ 96.82 with OLD engine
6R80 swap in progress
1968 Chevelle
NA/Pump Gas 10.4 @ 128 mph
416/4L85E LSA Supercharged build underway
