Results 1 to 6 of 6
Thread: HVAC Problem
    Long Island, NY
    HVAC Problem
    Had the seals changed on the EATC all air comes through the defroster vents.
    Thanks
    John
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    Mercury All Weather Mats
    1973 Oldsmobile Toronado
    2012 Kia Sedona Van
    2008 Corvette Convertible
    2021 Prius Prime Limited
    Member # 440
    ----- John
    May 2009
    Moreau Island
    Do the eatc self diagnostic test.
    https://www.youtube.com/watch?v=wSLjb8xh7Eg
    Unless the o-rings were not done correctly you have a vacuum leak.
    Places to look:
    Every vacuum line under the hood, especially the vacuum tree behind the intake on the firewall.
    The vacuum tank, square plastic box on the left side inner fender cover.
    Check all the vacuum lines under the dash going to the various motors and the EATC.
    BTW... the EATC self test won't detect a vacuum leak condition.
    Check here for the common problems with the HVAC system
    https://www.mercurymarauder.net/foru...-HVAC-PROBLEMS
    Can I ask who did the o-rings for you? You can reply with a PM......
    ok, car ruuning check the vacuum box on the drivers side fenderwell, you should have 14 inches of vacuum... This should reallllly suck down your finger when the car is running. If it barely has any vacuum there, then i would check the vacuum tree under the wiper cowl, or check vacuum leading to the tree...
    I have had 2 cars recently that had plenty of vacuum to the black box on the drivers fender, but barely any vacuum leading to the HVAC. The hose that goes thru the firewall, directly above the gas pedal is the black hose that feeds the HVAC unit. BOTH cars had the hose cut inside the grommet that passes thru the firewall. This will resolve your issue.
    Long Island, NY
    What do those codes mean?
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    2012 Kia Sedona Van
    Member # 440
    ----- John
    You forgot to post the codes.
  1. HVAC Self Diagnostic
    By biggeorge04 in forum Shop Talk
    Last Post: 09-21-2011, 10:52 AM
  2. HVAC???...what gives
    Last Post: 09-21-2011, 10:50 AM
  3. HVAC Vent Problem
    By sheriffbigd in forum Shop Talk
    Last Post: 09-15-2011, 10:47 AM
  4. HVAC gone crazy
    By Donald in forum Shop Talk
    Last Post: 05-06-2006, 08:43 PM
  5. Possible HVAC problem...
    By marauder307 in forum Community Discussion
    Last Post: 01-11-2004, 10:53 AM
