Results 1 to 7 of 7
Thread: Transmission pan and Valve Body
    For Sale:
    OEM 4R70W transmission pan with reusable gasket and bolts.
    This came off my Marauder with less than 4,000 miles on it.
    (Back in 2004, I put a Hughes aluminum deep sump pan on with stainless steel bolts.)
    $50 plus shipping in CONUS
    OEM 4R70W Valve Body.
    This also came off my Marauder with less than 4,000 miles on it.
    ( At the same time, in 2004, I bought a brand new Valve Body with the J-mod and heavier plate from Level 10 transmissions so I could do an immediate swap.)
    $200 OBO plus shipping in CONUS
    No pix of the Valve Body because it's sealed in a heavy plastic bag and dripping with trans fluid.
    Sep 2008
    USA
    Would you consider selling just the gasket and bolts?
    Thanks
    Ex Panther Owner
    I'd rather sell everything together.
    Sep 2008
    USA
    Gotcha.
    I ended up finding my old pan and bolts.
    Ex Panther Owner
    Trans pan BUMP!
    SOLD!!.....and delivered.
    Dec 2018
    Albemarle,NC
    Thanks Joe
  1. Custom Valve Body (Jmod)
    By Invective in forum Transmissions
    Last Post: 08-26-2018, 07:44 PM
  2. J-MODed Valve body on Ebay !
    By BeeDamn in forum Transmissions
    Last Post: 03-04-2015, 07:56 PM
  3. Manual Valve Body
    By JBFTech in forum Transmissions
    Last Post: 03-07-2013, 03:16 PM
  4. Which shift kit/valve body to buy???
    By USMCmarauder in forum Transmissions
    Last Post: 04-02-2007, 10:25 AM
  5. Mach 1 Valve Body?
    By Marauder.45 in forum Transmissions
    Last Post: 05-04-2006, 10:09 AM
