Results 1 to 15 of 21
Thread: I Need the Positive Battery Cable....
    Jan 2005
    Just South of Memphis, TN
    I need (new or used in good shape) the POSITIVE Battery harness for my 2004 Marauder.
    Local dealer says it's not available or even made anymore. Also harnesses for Crown Vics and Marquess will not fit...?
    He said the old part number is 3w7214300ca...
    Anybody got any suggestions for me... ;-)
    The old one got seriously corroded under the red rubber covering so I did see it until it was too late. Which is weird because the engine bay gets washed every time I was the car (very often)...
    All suggestions appreciated....thank you, will be back on line tomorrow (Friday).
    Architect
    "Ford Racing" 410 gear
    18"X8.5" Black Bullitt Wheels
    "Ford Racing" Center caps
    Black Wilwood Brakes (fronts)
    "Powered By Ford" coil covers
    30% Window Tint
    "X-pel" Light Shields
    "Pro-gard" skid plate
    Rear Spoiler
    "Kenny Brown" dead pedal
    "Megs" delete resonator tips
    "SS" Titanium Inserts
    Blacked out window trim
    Dec 2019
    NJ
    Blog Entries
    7
    I had the same problem, I cut out the old connector and put in a new one. I ran into the same issue, (parts not available)
    Posting a picture of my fix
    Sent from my SM-G715U using Tapatalk
    2003 Black 300A #3545 DOB 8/14/2002
    Steeda Underdrives
    BBK 65MM Throttle Body
    Transmission optimized to the nines by yours truly
    Marty Ochs Tunes
    Auburn LSD, FPP 3.73's
    Stainless Works Exhaust
    ADTR Henious Billet Arms
    ADTR Ridetech "Coilovers"
    Addco Sway Bar
    PS Z32 Brakes
    N a Whole lot more
    May 2009
    Moreau Island
    FBM might be able to fab one for you. Give him a shout out.
    Yes I can make you one.
    Jun 2007
    Whitehall, PA
    I’ve heard the vic harnesses are the same with exception to location of the clips to locate it on the cam cover studs.
    2003 DBP/LF - # 36 (sold)
    2003 DBP/LF - # 205 (sold)
    2004 Black - Trilogy #43
    2003 Black - shitbox (sold)
    2004 DTR - shitbox #2
    Oct 2014
    Cunningham, Kansas
    Yup, get one for a Crown Vic or a Marquis of similar year. I have a new one of those in my tool box.
    Jan 2005
    FBM... that really sounds great... do you have a picture of one you have made...?
    Would you give me an estimate of the cost... sounds like a lot of tedious work.. ;-)
    Thank you for your offer.... Architect
    30% Window Tint
    Rear Spoiler
    Jan 2005
    Thanks for your time and help...Architect
    30% Window Tint
    Rear Spoiler
    Nov 2006
    Union City, CA
    Ditto, that is what I remember hearing on this site.
    1988 LTD Crown Victoria S
    Nov 2006
    Union City, CA
    Jan 2005
    Here is a follow up thought... I wanted to cut the cables and remove the clamp only... then add cable as needed (soldered and matching gauge) and a new clamp... insulate as needed and we are done....
    Any thoughts.... I have the expertise and it's so much easier.... Marked battery picture.jpg
    30% Window Tint
    Rear Spoiler
    Jan 2005
    Edward Myers... Is the clamp you used from Amazon...? It has like 4 wire holes and set screws to hold the wires in the clamp... looks like a good design....
    Thanks, Architect
    30% Window Tint
    Rear Spoiler
    Go down by the starter and pull back that insulation. I guarantee you will find twice the amount of corrosion as you did up top. I went thru this with my ‘04 F150 after a new battery and also adding a 4.40:1 gear reduction mini starter to up the crank over speed only to finally see all the corrosion at that end..
    New pos harness with new 950 CCA battery and the high torque starter later and it damn near turns over faster than it idles! Almost sounds like a super car turning over.
    Same in the Marauder minus new cable but big 3 added, and an even smaller billet version of same starter.
    Both vehicles start with zero effort.
    Sep 2006
    Psych ward
    The only difference is the one connector with the yellow with grey tracer, which you can switch out the pin connector and solder back into the marauder connector!
    I know because I have that harness!
    Quote Originally Posted by Architect View Post
    Architect
    • 82 GT coyote swap started
    Sep 2006
    Psych ward
    EF7C3CAA-0FA7-4241-93DF-FB3AE24C7B04.jpgThe connector I’m showing is the one you have to modify
  1. Any Diff between CV battery cable and MM cable?
    By Agent2006 in forum Shop Talk
    Last Post: 11-20-2018, 05:12 PM
  2. Battery Cable Trivia
    Last Post: 07-22-2017, 02:34 PM
  3. Battery Cable
    By montazch in forum Power Adders
    Last Post: 09-21-2015, 12:58 AM
  4. Rotten Positive Battery Cable
    By ledzilla in forum Shop Talk
    Last Post: 05-12-2015, 12:08 PM
  5. positive cable..
    By bugsyc in forum Shop Talk
    Last Post: 11-05-2012, 03:21 AM
