Hello, hope you can help me out, I need a fuel pump for my 2003 M.M., having problems trying to find one, I have it down to being a DELPHI
PSS205, is this pump the stock one or an after market one?, anyone know of a supplier for it?. Thanks
I got a stock Motorcraft from RockAuto a year or so ago. Use the code for an extra 5% off. If you drop the tank remember to get the replacement snap off strap bolts to make your life easier when putting the tank back in place. Think I remembered that correctly.
Thanks for reply, my mechanic said I need the one specific to the m.m., a high pressure design, I assume your car runs fine with
stock ford one though, or was it a high pressure model.
Upgrade it to the aeromotive 340.
Is your car stock? Do you have a power adder?
Your Delphi number comes up with nothing. Cal your local ford dealer with vin number, see what they say.
