Results 1 to 15 of 15
Thread: Blend Door Actuator replace now airbag light on.
    Dec 2020
    Los Angeles California
    Well, my ac is working great now. thanks to the sticky. Now These issues popped up after I connected the battery.
    1. Airbag light is on, I checked connection and it’s tight
    2. Radio turns on but no speakers
    3. Power steering feels stiff
    What can be the problem?
    Jun 2020
    New Jersey
    Look up a fuse diagram and see if there’s a fuse that controls the speakers, power steering variable assist, and airbags.
    There is a module behind glove box for steering..ras module, which I think is for steering and airbag.. maybe it got knocked or diaconnected or a wire pinched doing blend door.
    Feb 2006
    Rosemount, MN
    My power steering was stiff, so I lubricated the U-Joint under the hood on the drivers side down by the exhaust manifold.
    Dec 2020
    Thanks fellas, I will check all this and let you know the outcome tomorrow.
    Jun 2020
    New Jersey
    Quote Originally Posted by Pantera View Post
    Any update?
    Dec 2020
    Just got done. checked all the above and no luck. Maybe Friday I will take it in and run a diagnostic on it.
    For some reason it feels more ballsy now. Weird.
    Module does ras vaps.
    steering and air ride...
    check all your fuses , maybe pinched a wire putting the air bag back in
    Sep 2005
    APPLE VALLEY,CA
    Check fuse 18. Can you see the temperature on your HVAC?
    Fuse #18? That's for the fog lights. Fuse #23 is for the EATC.
    OP, check fuse #16(15A) in the fuse box in the passenger compartment, #114(30A) in the power distribution box under the hood (behind the battery) and #115(50A) - feeds #16 inside.
    Did you take out the radio to change the blend door actuator? Check the connectors that plug into the radio. They should "click" in.
    See post #10 for power steering issue.
    Airbag, try disconnecting the battery for a few minutes. Make sure the connector to the airbag is tight and making good contact. No pinched wires.
    Sep 2005
    APPLE VALLEY,CA
    Sorry, I meant 16. My range sensor will blow that.
    Dec 2020
    The air ride on my marauder has been removed ever since I got it. Also the airbag light is on solid no intermittent blinks. But I will check more on this tomorrow before taking it in. Thanks for all the tips.
    Dec 2020
    Oh and regarding the question on the ac, it works great. I can see the temp.
    Dec 2020
    Finally figured it out. I feeel so dumb... There’s a plug under the right side of the glove box that connects with a gold color bolt. I loosened it when I wedged the dashboard thinking it was part of the disassembly and forgot to tighten it back up. Thanks guys for all the help. Its crazy all the problems this issue created.
  1. For Sale Blend Door Actuator
    By crownvic97 in forum Other Parts for Sale
    Last Post: 02-06-2019, 11:48 AM
  2. blend door actuator
    By Chayton in forum Shop Talk
    Last Post: 04-13-2017, 12:00 PM
  3. blend door actuator
    By MMARAUDER in forum Shop Talk
    Last Post: 04-07-2014, 04:27 PM
  4. Blend door actuator
    By BLACKMARAUDER04 in forum Shop Talk
    Last Post: 05-26-2013, 09:17 PM
  5. Blend Door Actuator
    By kmastl in forum Shop Talk
    Last Post: 08-27-2012, 10:17 AM
