Results 1 to 5 of 5
Thread: Engine ground cable from negative battery post
    Oct 2020
    Chandler Arizona
    Hey Guys,
    Question; in my overly enthusiastic ripping out my battery originated cables about 1.5 yrs ago, when my supercharger-engine and tranny rebuild project started, I didn't get a good photo of where the negative cable from the battery attaches to the block (stock config). Would anyone happen to know? I've added a supercharger, so some of the front passenger side of the block is now unavailable.
    FYI - the little strap from the negative cable that connects to the fender wall right near the battery I got handled.
    Many thanks!
    -KK
    '03 Silver Birch. Stock rebuilt 4.L 32V DOHC, V7-JT blower w/ADTR kit, Shift kit in transmission, planning stainless work long pipes and cat backs. ECD for start up Feb 14 2021.
    Feb 2018
    Saudi Arabia
    Hey Guys,
    Many thanks!
    -KK
    Good thing i wasn't so excited as much as you two years ago when i ripped the engine and tranny out lol
    One to the frame, you got it covered
    And one should be bolted to one of the valve cover bolts, you will find it joining the positive wiring loom from the battery and going to the starter the ground wire will stick out of the loom near the passenger side valve cover, but you can bolt it any where you like as long its bolted to the engine.
    Sent from my ASUS_I003DD using Tapatalk
    Stock was timing cover stud I believe.
    Oct 2020
    Chandler Arizona
    Thanks! Got it.
    Jun 2008
    Waukesha, WI
    This is correct
    2004 300A Procharger #0010 D1SC
    2003 300A Procharger #0017 D1SC (SOLD)
  1. Any Diff between CV battery cable and MM cable?
    By Agent2006 in forum Shop Talk
    Last Post: 11-20-2018, 05:12 PM
  2. Battery Cable Trivia
    Last Post: 07-22-2017, 02:34 PM
  3. Battery Cable Change, Looks like fun!
    By Fastbob in forum Shop Talk
    Last Post: 02-13-2016, 12:52 PM
  4. Battery Cable
    By montazch in forum Power Adders
    Last Post: 09-21-2015, 12:58 AM
  5. Battery cable guage
    By bugsyc in forum Shop Talk
    Last Post: 10-17-2011, 11:53 AM
