Results 1 to 7 of 7
Thread: Coolant Cross Over O-Rings
    Dec 2019
    NJ
    Blog Entries
    7
    If anyone needs o-rings for the coolant crossover I can supply 4 rings for 10$ (1 extra incase of a goof up). Thats alot better then 3 for 20$ + ship + tax from MMR. The quality is the same. Made of EPDM commercial grade rubber rated for water, steam and several other chemicals like Glycol (main coolant chemical). temp range from -70 F to 300F. I've got them on my Lincoln Aviator and have been doing just fine.
    P.S. click image to expand
    P.S.S I've cleaned a lot of those plastics and rubbers shes coming along nicely (Engine Swap, all new)
    2003 Black 300A #3545 DOB 8/14/2002
    Steeda Underdrives
    BBK 65MM Throttle Body
    Transmission optimized to the nines by yours truly
    Marty Ochs Tunes
    Auburn LSD, FPP 3.73's
    Stainless Works Exhaust
    ADTR Henious Billet Arms
    ADTR Ridetech "Coilovers"
    Addco Sway Bar
    PS Z32 Brakes
    N a Whole lot more
    Aug 2003
    Detroit, Michigan
    Where does the 3rd o-ring sit?
    Yours truly,
    Meteorite - Royal Oak, Michigan
    2003 300A - Black VIN = xxxxxxxxxxx600051 *** Build Date = 3/13/2002
    Best e.t. -- 12.31 @ 111.5 mph *** Now with: Trilogy #220, Alternative Auto Performance Tune + 4.10 Gears +SW headers + Metco control arms + Addco front and rear sta-bars + Dynotech Metal Matrix Driveshaft + Weldcraft widened wheels & MT drag radials.
    2003 300B - Blue
    And now ... 2003 Black (Trilogy #58)
    1962 Mercury Meteor & 1963 Mercury Meteor
    Quote Originally Posted by Meteorite View Post
    Between the pipes.
    Aug 2003
    Detroit, Michigan
    Between the pipes.
    Sorry if I'm being dense here ... but, between what pipes?
    I've taken off 3 Marauder crossover tubes now, and each time the crossover tube only had 2 O-rings on it.
    Yours truly,
    2003 300B - Blue
    The crossover tube is 2 pieces joined in the middle with a double O ring seal.
    Each 'downleg' has a single O ring seal.
    Pictures of COT in my previous For Sale thread:
    https://www.mercurymarauder.net/foru...OHC&highlight=
    Aug 2003
    Detroit, Michigan
    Between the pipes.
    Got it. Thanks, guys!
    Yours truly,
    2003 300B - Blue
    Apr 2010
    South Florida
    The COT takes (4) O Rings total. 2 in the center of the pipe, one on each side that go into the heads. Just to make it clear for everyone.
  1. Coolant cross over tube (risers) for blower
    By fairlane347 in forum Power Adders
    Last Post: 10-06-2020, 04:21 PM
  2. Stock coolant cross over tube wanted
    By fastblackmerc in forum Shop Talk
    Last Post: 12-12-2016, 12:07 PM
  3. Replaced coolant cross over tube
    By CHSurvivor in forum Shop Talk
    Last Post: 12-23-2014, 07:33 AM
  4. For Sale MM COT --- Coolant Cross Overtube
    By BODYMAN in forum Marauder-specific Parts for Sale
    Last Post: 03-12-2012, 02:35 PM
  5. Wanted To Buy cross over coolant tube
    By slickster in forum Marauder Parts/Misc. Wanted
    Last Post: 06-07-2011, 11:55 AM
