Results 1 to 7 of 7
Thread: The gray fuel hose that runs between the 2 metal fuel rails on my 03 MM
    Oct 2020
    Chandler Arizona
    Hey Guys,
    There is a grey fuel line that runs behind the lower intake manifold and connects the 2 metallic fuel rails.
    I had to grind off a small corner part of that lower intake in order to get the cooling mod connectors for the rear of the block to fit.
    I was lazy and didnt remove the fuel rails from the intake manifold while I did the grinding in the driveway on the manifold.
    I nicked the grey fuel line with the grinder - putting a very small cut in the line...it's not through, and its not deep, but it is worrisome to me.
    see below photos
    So...
    Anyone have an idea if that hose can be replaced?
    How to get it off, and how to get a new one, and how to get that new one on?
    Any other ideas to eliminate the idea of that line leaking with a hot engine in the immediate proximity?
    Does the Crown Vic and or GrandMarquis and or Mustang use the same config?
    Thanks
    -KK
    '03 Silver Birch. Stock rebuilt 4.L 32V DOHC, V7-JT blower w/ADTR racing supercharger kit, Shift kit in transmission, stainless works long pipes and cat backs, Ridetech coil-overs front, shocks in back (ADTR kit). OEM Mercury wheels, drop down mattress for under car comfort. ECD for start up (rev14) 4/15/21.
    Jun 2008
    Waukesha, WI
    I've never removed that hose, but if there is a barb underneath it you could remove it and replace with fuel injection rated hose and use crimp clamps. If you wanted to replace the whole fuel rail assembly, you need one from a Marauder.
    2004 300A Procharger #0010 D1SC
    2003 300A Procharger #0017 D1SC (SOLD)
    Blowing up the pic it appears to have 3-4 barbs. I’d just do what was already mentioned and move on.
    Oct 2020
    Chandler Arizona
    You can see the nick on the left and the barbed fitting (?) on the right.
    Crimp clamp & proper hose still the right approach ?
    Thanks guys
    Aug 2020
    New York
    Damn, you and me work the same. Did my cooling mod last week and did the same thing. So far not leaks or anything, but like you it is on my mind it got nicked. I was going to see if any members have a fuel rail, I am sure there are some out there
    2003 Marauder Purchased Feb. 2021
    Oct 2020
    Chandler Arizona
    Nick,
    I will go the fuel injector hose and crimps fix as suggested by Blazen above :-)
    Gonna be a while before start-up though, so be patient if you can.
    -KK
    I’ll check my stock tomorrow. I think I still have my original rails and an almost new Aeromotive set in red.
  1. Has anyone tried these fuel rails
    By sexygomer in forum Shop Talk
    Last Post: 12-08-2015, 06:59 AM
  2. New fuel rails
    By beanbag in forum Shop Talk
    Last Post: 06-16-2015, 09:18 AM
  3. For Sale fuel rails
    By na svt in forum Marauder-specific Parts for Sale
    Last Post: 07-16-2012, 07:02 AM
  4. fuel rails.
    By Seneca in forum Shop Talk
    Last Post: 09-24-2011, 03:50 AM
  5. Fuel Rails
    By saxman in forum Shop Talk
    Last Post: 03-28-2011, 02:45 AM
