Results 1 to 9 of 9
Thread: oil pressure dash gauge - which wire is it?
    Oct 2020
    Chandler Arizona
    Hey Guys, I'd like to use the wires from the stock oil pressure gauge to wire my new autometer "real" oil pressure gauge.
    I removed the stock gauge from the under dash panel, & took it apart. See photo. The wire ends you see in the photo connect to the old gauge (I cut them).
    The shown bulb can go right into the new gauge.
    I will run a 16awg wire from the back of the new sender to the back of the new gauge.
    BUT...the new gauge needs a power line and and ignition switch line...
    I'm not sure which is which of the 3 wires shown..
    1)black
    2)red/yellow
    3)red/white
    I've been pawing through my electrical wiring diagrams from shop manual, but I've not been able to figure it out from them.
    Anyone know?
    Oct 2020
    Chandler Arizona
    Sorry - back of new gauge needs ground, ignition (power) and wire to sender. So 2 of those 3 pictured (leaving out the bulb wires) I need to connect to the back of the new gauge..
    Apr 2010
    South Florida
    Use test light to find the ignition wire, new gauge needs all 3 wires to work.
    Oct 2020
    Chandler Arizona
    03Merc, Thanks!
    test light? Like a connect tester?
    Here is a pic of the wiring diagram I just found
    Looks like white/red goes to the sensor
    Red / yellow is ignition
    black is ground.
    Agree?
    Thanks again
    RD/YL - keyed voltage
    WH/RD - oil pressure sender
    BK - ground
    No need to run a new wire to the sensor. Just solder on a new eyelet connector.
    Oct 2020
    Chandler Arizona
    JB..thanks.
    I will solder the eyelet as you describe.
    Is it the rule that RD/YL is keyed voltage?
    AFAIK only at the pod gauges.
    Sep 2005
    APPLE VALLEY,CA
    Great information!
    Jun 2009
    Warsaw, Indiana
    1)black
    2)red/yellow
    3)red/white
    Anyone know?
    You can use the existing sensor line, which is what I did. Even if you couldn't, you don't need a 16 AWG wire for a gauge. There is an insignificant amount of current flowing to most kinds of gauge, so a 20 AWG wire would have no real voltage drop over that short a distance and is a lot easier to handle, solder/crimp and stuff through a firewall access!
  1. For Sale WORKING GAUGE POD W/ REAL OIL PRESSURE GAUGE
    By 510paesan in forum Marauder-specific Parts for Sale
    Last Post: 07-22-2020, 12:05 PM
  2. Oil Pressure Gauge
    By Fly007 in forum Shop Talk
    Last Post: 03-13-2016, 08:43 AM
  3. Under dash wire - what is it for?
    By stevengerard in forum Interior Electrical/Electronics
    Last Post: 04-25-2014, 01:11 AM
  4. For Sale Under Dash Gauge Pod & Boost Gauge
    By Mercguy04 in forum Marauder-specific Parts for Sale
    Last Post: 08-27-2013, 01:55 PM
  5. Fuel Pressure Gauge? A/F Ratio Gauge?
    By Rider90 in forum Shop Talk
    Last Post: 02-07-2006, 07:42 PM
