Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: Same tire size all around?
  1. #16
    Oct 2008
    Toronto, ON
    If you have an ‘04 then it will trigger the traction control and look dumb. If you have an ‘03 it will be fine doing that but look dumb.
    Dude, you've been on this site for such a long time. Why post this misinformation?? Look at the confusion you caused later in this thread.
    The staggered wheel sizes has nothing to do with '03 vs '04. It has nothing to do with '03A vs '03B.
    It has only to do with traction control. The only question that needs to be asked is "does your MM have taction control?"
    If YES, then staggered is required - all 4 the same size is not an option.
    If NO, then staggered is optional - you could go staggered if you want, or all the same if you want.
    It's that simple. Quit confusing folks.
  2. #17
    Mar 2018
    Las Vegas nevada
    Thank you guys for the help I didnt end up getting them im getting the same exact size that it needs ..yea im taking it to another tire shop and asking specifically for those sizes
    Sent from my SM-G970U using Tapatalk
  3. #18
    Oct 2020
    Chandler Arizona
    Thanks MBB,
    So if it is above 3% am I good?
    Or does it have to be between 3 and 6 % wrt tire diameter difference?
    Many thanks
    -KK
  4. #19
    Oct 2008
    Toronto, ON
    Thanks MBB,
    Many thanks
    -KK
    The difference must be between 3% and 6% (personally I believe the range to be tighter than that... 3%-5%)
  5. #20
    Some people run 235-50-18 and 255-55-18 which is 6.2% and is fine. Screenshot_20210425-065315.jpg
  1. tire size
    By burt ragio in forum Tires & Wheels
    Last Post: 06-09-2018, 07:03 PM
  2. Rim size to tire size
    By Mach in forum Tires & Wheels
    Last Post: 10-13-2014, 04:46 PM
  3. Tire size!!
    By drummerboi in forum Tires & Wheels
    Last Post: 02-19-2012, 09:41 AM
  4. Tire size
    By Coupe in forum Tires & Wheels
    Last Post: 03-13-2011, 10:59 AM
  5. tire size
    By bigmerc'03 in forum Tires & Wheels
    Last Post: 03-06-2007, 01:28 PM
