Results 1 to 9 of 9
Thread: Engine Fan Stuck On
    Jun 2002
    Hollywood, S.C.
    Engine Fan Stuck On
    My mechanic wants to put a new engine fan on my Marauder because it’s stuck on! I’m not sure that’s the correct? I was thinking a sending unit maybe the problem? If I connect the fan it will run when the engine is cold! I’m not afraid to spend for the repair I want to make sure we’re replacing the right part!
    Anyone else have this problem?
    2003 (#867 of #7839) 300A Marauder
    #23 MercuryMarauder.net member
    6/7/02 Build Date
    6/17/02 Purchased
    IL Plate MARAWDR
    35%Tint All Around
    Z&M Control Arms
    Real AutoMeter Oil Gauge
    Marauder Hats in rear window
    Rear Bumper Gray Decals
    Trunk Organizer
    OEM Frt Splash Guards
    ProGuard
    Weathershield Marauder Cover
    2XL Marader Jacket
    McGard Wheel Locks
    Marauder Billet Pedals
    Marauder Door Sills
    Denso Plugs IT20's
    8/3/03 Dyno 260.4 RWHP/291.3 Torque
    Engine Fan Stuck On
    There is a bit of diagnosing with this Gary. The fan relay or controller could be stuck, as well as a bad coolant temp sensor, A/C switch, or even a faulty trans temp sensor, all of which communicate with the PCM to turn on the fan as far as I know. I’m pretty sure one or two more items also involved in the PCM’s algorithms but currently drawing a blank.
    Mines been on high for probably four years now because lazy.. I’m pretty sure mine is the fact there is no more trans temp but I’m not motivated enough yet to add a resistor to trick it. Maybe next year.
    Jun 2002
    Hollywood, S.C.
    Bob thanks for the info. My fan is stuck on high also. So I think the fan isn’t the problem.
    6/7/02 Build Date
    6/17/02 Purchased
    IL Plate MARAWDR
    35%Tint All Around
    Z&M Control Arms
    Trunk Organizer
    ProGuard
    2XL Marader Jacket
    McGard Wheel Locks
    Marauder Door Sills
    Denso Plugs IT20's
    Jun 2015
    O'Hare IL
    The most common issue with a high fan stock on its a faulty temperature sensor, not the one for the gauge and it will also throw a MIL code, any codes?, well unless the sensor thinks it's within the parameter limits and makes the PCM to try to cool down the engine.
    Another very common issue is a faulty fan module, I would start by replacing this one.
    Jun 2002
    Hollywood, S.C.
    After finding a U tube video that was 34 minutes long . Where the tech had a fan stuck on high he diagnosed it as the fan motor which has a control module that is the culprit . But you have to buy the whole assembly. I will post later, I think I’m on the right path to fix this problem.
    6/7/02 Build Date
    6/17/02 Purchased
    IL Plate MARAWDR
    35%Tint All Around
    Z&M Control Arms
    Trunk Organizer
    ProGuard
    2XL Marader Jacket
    McGard Wheel Locks
    Marauder Door Sills
    Denso Plugs IT20's
    Jun 2015
    O'Hare IL
    Just an FYI, Not sure If I dreamed about it but I think I separated the module from the fan assembly once, or maybe I replaced the whole assembly.... One thing for sure I got mi replacement from the junk yard OE.
    you can get one from a grand marquis or crown vic they are the very same unit.
    I’m using the stock controller for a no where near stock radiator, fan, and shroud assembly. So yes, easily removable.
    Quote Originally Posted by chapel1 View Post
    Do not... I repeat DO NOT get an aftermarket fan assembly or controller. They have a habit of making "thermal" events.
    Jun 2002
    Hollywood, S.C.
    Noted ! I guess ill take a shot at OEM parts from a junkyard.
    6/7/02 Build Date
    6/17/02 Purchased
    IL Plate MARAWDR
    35%Tint All Around
    Z&M Control Arms
    Trunk Organizer
    ProGuard
    2XL Marader Jacket
    McGard Wheel Locks
    Marauder Door Sills
    Denso Plugs IT20's
  1. All gauges STUCK?? Help.
    By BlackBeauty_bb in forum West Coast Marauders
    Last Post: 02-02-2018, 02:48 PM
  2. Need Help Stuck and the Engine Lost Oil Pressure
    By jvillerauder in forum Shop Talk
    Last Post: 08-25-2012, 12:03 PM
  3. I'm stuck and someone's help!
    By TooManyFords in forum Shop Talk
    Last Post: 09-11-2006, 05:30 AM
  4. Stuck
    By jim geary in forum Community Discussion
    Last Post: 12-06-2005, 02:50 PM
  5. Stuck Fan
    By mailman in forum Shop Talk
    Last Post: 12-01-2003, 05:13 PM
