Results 1 to 15 of 18
Thread: ODB port not working
    Sep 2006
    Wyckoff NJ
    Hi,
    Ran into a issues where the ODB port stopped working..
    Scanner does not light up, anyone else run into this issue?
    Sep 2006
    Wyckoff NJ
    I have checked fuses, none seem to be blown.
    May 2009
    Moreau Island
    Does the scanner work in a different car?
    Sep 2006
    Wyckoff NJ
    Yes the scanner works in another car.
    May 2009
    Moreau Island
    According to the internet which never lies, the OBD 2 port is often piggybacked to another fuse such as the cigarette lighter or as the youngin's call it the radar detector plug. I'd pull and check the fuses that are power things even when the ignition is off.
    Jun 2007
    Whitehall, PA
    Is this for the abs or it doesn’t work at all?
    2003 DBP/LF - # 36 (sold)
    2003 DBP/LF - # 205 (sold)
    2004 Black - Trilogy #43
    2003 Black - shitbox (sold)
    2004 DTR - shitbox #2
    My OBD port was dead. After much investigation I found the power lead was "open" somewhere between the fuse box and the firewall(drivers side). The wiring bundle snakes across the front of the engine compartment making it difficult to trace the break. I cut the "+" lead behind the OBD port and added a female bullet connector(lower right pin #16 on the obd port-looking forward). A male bullet connector and wire and accessory plug goes to the accessory power outlet on the center console to power the OBD port. I keep the wire assembly in the center console with my code reader.
    Sep 2006
    Wyckoff NJ
    Quote Originally Posted by johnjamis View Post
    Looks like i have the exact same problem as you did....I noticed, while i was driving, that the scangauge stopped working...
    Sep 2006
    Wyckoff NJ
    Does anyone know which cable between the fuse box and the firewall(drivers side) that i should be looking for in the bundle of cables?
    Quote Originally Posted by mtenderenda View Post
    I'll check my wiring manual when I get home.
    Sep 2006
    Wyckoff NJ
    Thank you fastblackmerc
    Sep 2006
    Wyckoff NJ
    fastblackmerc did you get a chance to check?
    Sep 2006
    Wyckoff NJ
    Does anyone have a fix for this issue?
    I found no fuse in the owners manual for the diagnostic port.
    I'd check each fuse - pull it out verify continuity and fit in the socket.
    Sep 2008
    USA
    Ex Panther Owner
  1. port job?
    By 92BlackGT in forum Power Adders
    Last Post: 04-02-2014, 07:34 PM
  2. Cobra port job
    By Jokerzl in forum Jokerz Performance Ports
    Last Post: 01-25-2014, 11:36 AM
  3. OBD Port
    By Damien2003 in forum Shop Talk
    Last Post: 02-18-2013, 09:41 AM
  4. Service Port Not Working?
    By zrwhat in forum Shop Talk
    Last Post: 08-01-2007, 05:01 PM
  5. 12V port
    By Raudermaster in forum The Lounge
    Last Post: 06-21-2007, 10:41 AM
