Does anyone run 5W30 in the summer? I'm thinking about 5W30 Mobil 1.
0W-30 MOBIL 1 YEAR ROUND
04 DTR 42K M.
03 BLK 9K M.
07 GT500 10K M.
98 MARK VIII 70K M. BOUGHT NEW
21 EXPLORER PLATINUM 3.0
18 GENESIS G80 5.0
78 RANCHERO 5.0
54 GMC
I run 5w-30 always.
After using pure Dino-Oil for the first couple changes...I've used this ever since, with the standard Motorcraft Filter
I always run 5w-30
5-W30 here too
First retailed 2003 Marauder
Bought 6 June 2002
#168
Thanks for the responses.
5W-30 Mobil 1 for summer, this is my first summer with the car
2003 Marauder Purchased Feb. 2021 from original owner 62,000 miles
Cylinder Head Cooling Mod from Marty
K&N Cold Air Intake
SCT 4 with custom Tune
Stainless Works Cat Back exhaust with Magnaflow 10416 mufflers
4:10 gears with Cobra Carbon posi disc and Ford Girdle cover
Real Oil pressure gauge Autometer
Morimoto XB LED fog lights from Panther Lights
Headlight bulbs GTR Lighting Ultra 2.0 from Panther Lights
TCI Trans. Pan
Aeromotive 340 fuel pump
Motorcraft 5/30W full synthetic during warm months. Castrol 5/30 50/50 during cold months.
If you have a working relationship with a local Ford dealership (IOW, spend money there), service department could have excellent prices on lubricants and filters. They buy that stuff by the pallet and drum. Best prices I found for MERCON V and full synthetics were at the local Ford store.
Motorcraft PH2 oil filters have a stop drain valve. Don't know about Wix but most others don't. Walmart.
The correct Motorcraft oil filter part # is FL-820-S.Chico Baravelli... Motorcraft PH2 oil filters have a stop drain valve. Don't know about Wix but most others don't. Walmart.
PH2 is the part # of the FRAM and should not be used. There are several TSBs put-out by other auto makers noting issues with FRAM oil filters and voiding engine warranties due to its drain-back valve (which is rubber/nitrile).
Motorcraft oil filters have a heat resistant silicone anti-drainback valve. Other quality oil filters that also have this are: WIX, and NAPA GOLD | SLIVER (which are made by WIX)
Summary:
What gdmjoe said. My bad.
However, There is a Fram on my car because I did a Seafoam before and moly after the oil change. It will come off after 300 - 400 miles and a FL-820-S will go on.
AIR, Chrysler issued a SFB because oil pressure sensor failures and sometimes oil shop techs would let spring valve seats drop into black oil buckets and not know what they've done.21213
I run 5W-30 Walmart full synthetic year round, change it every 5K, and I ONLY use Motorcraft FL820-S oil filter. I have a cheapie catch can I made from a Harbor Freight air compressor oil separator, which fills up very slowly.
Costco Mobil 1Sythetic on sale is a steal! Or Motorcraft OEM at Walmart.
I run Mobile One 0W30 & FL820S. Change every 5k.
This was what I did for entire time I owned a Marauder, 15+ years.
Bill
03 Mercury Marauder, 300A
SOLD
2005 Lincoln Town Car, ADTR Supercharger, TCE Brake Lines, MO's Tune
2022 Lincoln Aviator Reserve AWD
