Results 1 to 15 of 18
Thread: Blower speed
    Dec 2010
    Topeka, Ks
    Blower speed
    When I use AC on automatic function the blower speed has recently become erratic. What do y'all think? TIA
    BW
    May 2021
    Burns, Oregon
    Belt or exhaust drive? Does engine RPM or exhaust tone also change? What happens when AC switches off? First guess: PCM is not adapting or attempts to but is off the map.
    Wisconsin
    Quote Originally Posted by 04 Quicksilver View Post
    BW
    Supercharger blower or HVAC blower?
    TIA? transient ischemic attack?
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
    BCM on its way out?
    Dec 2010
    Topeka, Ks
    It's the HVAC blower. What's involved in investigating and replacing BCM?
    Dec 2010
    Topeka, Ks
    Thank you, sir. Looks to be beyond my mechanical skills. Will get in touch with my technician.
    Neil that used to work at Firestone opened a shop in Lenexa Kansas
    autopia llc http://www.autopiakc.com/
    Dec 2010
    Topeka, Ks
    Thanks for the info.
    north nj (Planet Houston)
    haha. Thanks In Advance
    Dec 2010
    Topeka, Ks
    Problem(s) solved. BCM replaced; right front window stopped, window regulator replaced; intake manifold gasket replaced. Tech said module was a little rough but he did not have to remove any hoses. Parts $202, labor $315. I already had the gasket. Great customer service. The guy's a wizard!
    Jan 2011
    Chicago
    I took the car out last week and tried to turn the A/C on and nothing happened; blower motor didn't come on at all; what could possibly be the problem? I have heard blower motor or resistor..
    Sep 2005
    APPLE VALLEY,CA
    It was probably your BCM (Blower Control Module). When they get really hot, the solder joints melt and the unit fails.
    My black is on its third, My silver is still on its original.
    I sent out my extra BCM ( I keep one on hand) to fastblackmerc. He will fix the solder joints so the new unit once installed,
    will not fail. Also check your fuse.
    Just check the blower 2 wires. If it has power and ground and not working, then the blower motor needs replaced.
    if there is no power and ground then BCM or fuse
    Dec 2010
    Topeka, Ks
    Thanks to Jim for repairing my original BCM which I will have for a spare.
  1. Weak AC / heat blower fan speed
    By Drewstang in forum Interior Electrical/Electronics
    Last Post: 05-12-2017, 04:50 PM
  2. AC and blower speed problems
    By DS650 in forum Shop Talk
    Last Post: 06-01-2014, 06:16 PM
  3. Blower Motor/Fan Speed Varies
    By WhatsUpDOHC in forum Shop Talk
    Last Post: 06-23-2011, 05:16 AM
  4. Blower Motor Speed Control
    By MMinMN in forum Shop Talk
    Last Post: 11-07-2009, 05:56 AM
  5. How to determing if its the AC Blower or AC speed control?
    By dohc324ci in forum Community Discussion
    Last Post: 03-27-2009, 04:06 AM
