Results 1 to 5 of 5
Thread: oil pressure switch electrical connection
    Jun 2010
    Boston
    I have a new oil pressure switch and gauge.... I am trying to take of the electrical connection and I know you need to push down on the clip but it will not budge.
    Anyone been through this?
    Apr 2010
    South Florida
    Just cut the wire, You need to anyways for a real oil pressure sending unit.
    Jun 2010
    Boston
    yeah I did not want to cut the wire but guess I have to since the new pressure switch just has a screw to hold the wire..... Thanks....
    Apr 2010
    South Florida
    Quote Originally Posted by bluesboyst View Post
    Put one of these on it.
    Jun 2010
    Boston
    I was able to take the old oil pressure switch and used the connector from that and soldered a wire to it that attached to the new oil pressure switch... No cutting....I believe it is just the oil pressure switch that is the issue... I did not change the gauge and now it reads about 33 PSI and when I rev the engine it goes up to about 50....I will eventually put in the new gauge...
  1. Replies: 31
    Last Post: 05-16-2015, 03:00 PM
  2. need stock oil pressure switch part number
    By 88CuttyClassic in forum Interior Electrical/Electronics
    Last Post: 08-02-2014, 04:07 AM
  3. Wanted To Buy power steering pressure switch
    By 707marauder in forum Marauder Parts/Misc. Wanted
    Last Post: 03-03-2012, 10:29 AM
  4. Wanted To Buy Oil pressure switch
    By Coupe in forum Marauder Parts/Misc. Wanted
    Last Post: 11-07-2011, 01:46 PM
  5. Replies: 3
    Last Post: 12-30-2010, 08:46 PM
