Results 1 to 9 of 9
Thread: 03 Marauder Coolant Hose Replacement
    Jul 2021
    Ohio
    Hi Guys ,
    I have a 44,000 mile black Marauder bought new in 3/03 with all of the original hoses . I'm taking it on a 2,500 mile road trip this summer and figured it to be wise to replace the hoses . I saw the thread about where to buy the correct radiator hoses . How many other hoses are on this car and where do I find them ? (I see the 2 small hoses to the throttle body , 2 to the heater and 1 on the P/S side front of the engine )
    May 2009
    Moreau Island
    Try RockAuto, sponsor here, use discount code. Some you can find at your local Ford or Flaps. The remaining you will need to invent from other hoses that match the bend pattern of the original.
    Lehigh Valley, PA
    You're not going to find every hose you need, specifically the one that runs from the crossover tube to the thermostat. Rockauto suggests a universal flexy/bendy hose instead. The original hose is long NLA from Ford.
    You're better off keeping what you have now with such a low mile car unless they're swollen or have abrasions. If you do want to replace things, the lower radiator hose is available as is the upper, but the one that goes from the block to the thermostat housing was a bit small, I had to really stretch it to fit when I did this job on my 03 Marauder a couple years ago.
    My advice, flush the coolant out, fill with fresh stuff, and go have a drive.
    2063/3214
    5377/7838
    Quote Originally Posted by tl63 S-55 View Post
    Hi Guys ,
    If you can wait until I get back into work I'll post all the P/N's for the hoses, etc.
    Made a list after replaceing my cooling system hoses
    Cooling System:
    Lower radiator to thermostat housing: Gates 22812
    Crossover to top of radiator: Gates 22810
    Crossover to thermostat housing: Dayco C70986
    Oil cooler to thermostat housing: Dayco E72103 (you will only need a portion of this hose) lower radiator hose for a 2004 Lexus GS300. Reuse old spring
    Reisch Performance Thermostat: FORD-4D
    All other hoses are bulk items at any FLAPS
    May 2009
    Moreau Island
    Make these numbers a Sticky powers that be.
    Winston Salem, NC
    yes, yes!!!
    2003 300A
    Eaton Swapped by Curless
    Brake Upgrade
    Mo's Tune
    JLT Intake
    Addco Sway Bars
    ADTR Coil Over Suspension
    SW Headers and Exhaust
    Accessories By FastBlackMerc
    4.10 Gears
    Aeroforce Gauges
    Pantherlights Headlamps
    Jul 2021
    Ohio
    Well , the job is done and the trip went fine for the most part . I will say that the 2 hoses behind the P/S valve cover SUCKED to get to !!! While everything was apart I also changed the water pump with a new Ford unit , and also changed the belt tensioner as it was occasionally making noise . 1 of the heater hoses was readily available and the other had to be created from a 5' piece of hose with 3/4" on one end and 5/8" on the other .
    Next time around pop the wiper cowl assembly off. It’s pretty much step one of a number of things to make easier.
  1. Coolant hose - the short one
    By azgolfrat in forum Shop Talk
    Last Post: 11-06-2020, 11:56 AM
  2. Brittle coolant hose
    By drgnrdr33 in forum Shop Talk
    Last Post: 01-13-2020, 07:29 PM
  3. Coolant Hose Question
    By Ambitious1 in forum Shop Talk
    Last Post: 11-29-2016, 06:21 PM
  4. For Sale Coolant hose tube
    By etobicokian in forum Marauder-specific Parts for Sale
    Last Post: 05-31-2016, 04:35 AM
  5. PCV Coolant Hose?
    By bolsen in forum Shop Talk
    Last Post: 04-11-2012, 04:05 PM
