Results 1 to 15 of 28
Thread: Searching for New Fuel Pump -1st time-
    Charlotte, N.C.
    Believe it or not i am still on my OEM fuel pump with my Super Charged engine --am at 75K on the clock and 53K on the super charged engine.
    My recent tune indicated the need to replace it along with a higher amp alternator--so I have already purchased the upgrade to an 160 amp alternator--still in the box-- so now the search is on for the fuel pump.
    Problem is , this subject has been around for a long time and there are many opinions on it--some say the GT-40 is best others say that it is not etc..--but no matter what, the whatever one I get, needs to be a better performer and of course "fit" size wise-
    So as easy as it may seem to do , it is major for me to be right on both subjects..
    So if I could get some feeling towards what is your opinions and why including any specs I would appreciate it very
    much --
    thanks you so much!
    Tom
    12.45 at 109.6 MPH
    1.92 Sec .- 60 '
    Alt .SSHS 9 --11/7/09
    '06 CV P71 Street Pkg
    Interior Marauder Floor Shift
    All New Parts
    In Memoriam....11-14-13
    Apr 2010
    South Florida
    Aeromotive 340.
    The Dirty South
    ^^^^^^Not ok if your running a BAP
    Jun 2019
    VA
    I am pretty sure this is the Ford OEM Part # for the 2005-2006 Ford GT Fuel Pump which I'd highly recommend.
    MOTORCRAFT
    PFB81#4G7Z9A407CA
    My original 340 was used with one for almost 6 years before switching over to return style and adding a second one 6 years ago. Still going strong.
    The Dirty South
    http://kennebell.net/wp-content/uplo...ump-Tech-1.pdf
    Quote Originally Posted by BackNBlack View Post
    MOTORCRAFT
    PFB81#4G7Z9A407CA
    I thought that FORD no longer offered the GT pump....which was a very good pump.
    Wisconsin
    Heck! I'm getting a Hellcat pump! (OUCH!!! Maybe not, $800+!)
    I'm running an Aeromotive 340 with BAP, so far runs like a top...
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
    Sep 2005
    APPLE VALLEY,CA
    $118+ for this at Fordpartsgiant. Actually costs less than the Bosch I put in the Marauder last week.
    Long Island, NY
    Motor Craft is the only way to go.
    Just had mine replaced.
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    Mercury All Weather Mats
    1973 Oldsmobile Toronado
    2012 Kia Sedona Van
    2008 Corvette Convertible
    2021 Prius Prime Limited
    Member # 440
    ----- John
    Charlotte, N.C.
    I don't see what YOUR REFERRING TOO........
    12.45 at 109.6 MPH
    1.92 Sec .- 60 '
    All New Parts
    Charlotte, N.C.
    Quote Originally Posted by jgc61sr2002 View Post
    BUT IS THAT STOCK ON STOCK ENGINE OR SOMTHING ELSE? THANKS
    12.45 at 109.6 MPH
    1.92 Sec .- 60 '
    All New Parts
    Charlotte, N.C.
    MOTORCRAFT
    PFB81#4G7Z9A407CA
    Thank you Mr. BackNBlack will check it out as well--
    12.45 at 109.6 MPH
    1.92 Sec .- 60 '
    All New Parts
    Charlotte, N.C.
    I noticed that the one referenced by fastblackmerc above on eBay is same as that one from "backnblack" previously with one exception--
    the numbers are the same except at the end one has "CA" the other "AA"
    wonder what significance that must be ?
    Anyone have an idea?
    Thanks so much
    12.45 at 109.6 MPH
    1.92 Sec .- 60 '
    All New Parts
  1. Replies: 6
    Last Post: 09-22-2015, 09:36 PM
  2. fuel pump energize time/demand
    By BigM460 in forum Tuning
    Last Post: 04-07-2015, 07:35 AM
  3. Maxflow® Fuel Pump Booster or KB boost a pump
    Last Post: 01-14-2013, 09:41 PM
  4. Replies: 13
    Last Post: 07-08-2008, 05:41 AM
  5. Replies: 47
    Last Post: 03-13-2008, 05:59 AM
