Results 1 to 7 of 7
Thread: Running at Willow Springs with SpecP71
    Apr 2020
    Glendale AZ
    Finally had a chance to run with the Spec P71 boys, had a lot of fun turning laps at Big Willow. Far and away the fastest track I've been on, hit 100 in 3 places and topped out at 120 at the end of the straight, for a fastest time of 1:47. Slower than the spec class winner, so I've got some more driving to learn. Anyways, enjoy the pictures, and if you're thinking of coming to a track day, just do itttttttt
    Sep-11-2021-Speed Ventures (Sat)-5-purple-Turn 1 (Session 2)-WS2_8682_Sep1121_1149AM_CaliPhoto.jpgSep-11-2021-Speed Ventures (Sat)-5-purple-Turn 3 ( Session 3)-WS2_0665_Sep1121_223PM_CaliPhoto.jpgSep-11-2021-Speed Ventures (Sat)-5-purple-Turn 3 ( Session 3)-WS2_0760_Sep1121_230PM_CaliPhoto.jpgSep-11-2021-Speed Ventures (Sat)-5-purple-Turn 4 (Session 1)-WS2_5857_Sep1121_936AM_CaliPhoto.jpgSep-11-2021-Speed Ventures (Sat)-5-purple-Turn 4 (Session 1)-WS2_5861_Sep1121_936AM_CaliPhoto.jpgSep-11-2021-Speed Ventures (Sat)-5-purple-Turn 4 (Session 1)-WS2_6298_Sep1121_945AM_CaliPhoto.jpg
    Wisconsin
    DANG! That's a heck of a steep hill in pic 1!
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
    Timbuk3, MI
    Question
    daniel.drives...
    Noticed that you don't have any of the front lower air deflectors. On purpose -or- oversight?
    Feb 2006
    Rosemount, MN
    What wheels are you running? Diameter and width?
    Winston Salem, NC
    This is just too cool! Looks like big fun!
    2003 300A
    Eaton Swapped by Curless
    Brake Upgrade
    Mo's Tune
    JLT Intake
    Addco Sway Bars
    ADTR Coil Over Suspension
    SW Headers and Exhaust
    Accessories By FastBlackMerc
    4.10 Gears
    Aeroforce Gauges
    Pantherlights Headlamps
    Feb 2006
    Rosemount, MN
    And what brake rotors and pads are you running? I run several auto cross events each year and I run the stock size rotors but I run a CarboTech AX-6 pad on all four corners. Do you run an additional transmission cooler?
    Apr 2020
    Glendale AZ
    Myblackbeasts - Yes it was, good thing I had some momentum to make it up haha
    GDMjoe - you are correct, I never got around to re-installing them when I rebuilt the front end. I'm currently trying to set up brake ducting from the foglight holes, once I do that I might reinstall them. Havent noticed a problem, but idk
    Crouse - These are Mustang 2015 anniversary edition, 19x8.5. I got them after I didn't like the amount of sidewall flex I was getting on the stock 18s, and they did increase the steering precision, but also breakaway is much more sudden than with the extra sidewall. I'll keep running them for the time being, but I'd be interested in throwing the same (model of) race tire on 18s and seeing the difference. Rotors are stoptech slotted up front, stock in the back, Hawk HPS all the way around with preston DOT4 fluid (its what my local parts store had the night I needed it). I've heard good things about the Carbotech, but I've been satisfied enough with the Hawk I haven't switched. I will say the slotted rotors helped so much more with brake fade than I anticipated, at the expense of eating the front pads. I'm currently researching trans cooler options, I hit 285 at this event when it was like 100 degrees out, amazingly everything still works. Drained and filled fluid as soon as I got home. My biggest restriction is that I absolutely need to keep the AC condenser, which limits my options.
    Peace2peep - Absolutely is a lot of fun!
There are currently 5 users browsing this thread. (0 members and 5 guests)
  1. Replies: 42
    Last Post: 03-13-2019, 03:11 AM
  2. Marauders at Willow Grove, PA
    By hwy73 in forum North East Marauders
    Last Post: 10-15-2007, 07:14 AM
  3. Save Willow Grove
    By TheDealer in forum North East Marauders
    Last Post: 08-24-2005, 09:07 AM
  4. Willow Springs MM?
    By Fastronald in forum Windy City Marauders
    Last Post: 07-02-2004, 12:45 PM
  5. Willow Springs Raceway March 12
    By JamesHecker in forum The Lounge
    Last Post: 03-07-2003, 05:04 AM
