Results 1 to 10 of 10
Thread: Eaton Swap WOT battery light
    Oct 2010
    Michigan
    This problem has just recently started to happen where from a stop, without brakes and hitting the pedal to the floor.
    The problem is that last time I did this, the battery light came on, volt gage read low and putting the car in park, it idles at 1500 RPM.
    I changed the battery because it was 8 years old.
    Also noticed the alternator wasn't charging the battery while running and putting a load on the electrical system by running everything electrical I could.
    So, after changing the battery and alternator, the battery light didn't come back on and everything was fine until I peeled out again and now with a new battery and alternator, I have the battery light on again, volt gage reads low again and when parked, the car idles high at 1500 RPM...AGAIN!
    Has anyone ever experienced this with a boosted car in-particular?
    If so, what was it that caused this to happen?
    Have you checked your connection at the Alternator extension splice?
    Rule of thumb, check everything ever messed with first.
    The Dirty South
    Mine did the same thing on the dyno. Good thing because we data logged it.
    Alternator....
    Oct 2010
    Michigan
    Thanks for the suggestions.
    Checked the wiring and all is good.
    The alternator was a reman, so I have a brand new unit arriving soon.
    Hoping that was the variable which caused this.
    Wisconsin
    Does the alt still have a clutched pulley on it?
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
    May 2009
    Moreau Island
    Was the reman unit a 4G alt? White pluginski IIRC.
    The Dirty South
    Can't with an eaton swap. The pulley will hit the timing cover
    Wisconsin
    So much for that thought!
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    JL 6.5 SubWoofer
    Mo's Dyno Tune
    Aug 2012
    Kansas City
    Well, this is the tell tale sign that it is time to sell me that Eaton Swapped car of yours. I am kidding. Very odd problem though. Obviously the tires are spinning...... high RPM...... vibration through the drivetrain....... check all the wiring you extended or moved, and CHECK ALL GROUNDS. Let us know what you find. Very interesting issue.....
    Neil
    2003 Mercury Marauder - SB/LF
    Oct 2010
    Michigan
    Yes it was.
    +1 on the white pluginski!
    UPDATE
    Just got to installing the brand new alternator and no more issue.
    I tried to grab a DB Electrical alternator, but every option on their website says unavailable.
    Tried calling them, but the guy on the phone wasn't much help.
    Hoping the famous 200 amp model becomes available again as I would like to have an upgradeable spare.
  1. For Sale New Battery Tray for Eaton Swap
    By krussell1203 in forum Marauder-specific Parts for Sale
    Last Post: 03-03-2017, 06:15 PM
  2. Eaton swap Optima battery
    By tdotcv in forum Power Adders
    Last Post: 04-07-2015, 12:46 AM
  3. battery for Eaton swap
    By mw2309 in forum Power Adders
    Last Post: 10-05-2014, 04:26 PM
  4. battery cables for eaton swap
    By loud2004marquis in forum Shop Talk
    Last Post: 07-06-2012, 02:57 PM
  5. New battery and Eaton swap
    By dmjarosz in forum Shop Talk
    Last Post: 11-14-2010, 12:02 PM
