Tried search with not much luck. Anyway to have fog lights stay on with High Beams????
2003 Marauder Purchased Feb. 2021 from original owner 62,000 miles
Cylinder Head Cooling Mod from Marty
K&N Cold Air Intake
SCT 4 with custom Tune
Stainless Works Cat Back exhaust with Magnaflow 10416 mufflers
4:10 gears with Cobra Carbon posi disc and Ford Girdle cover
Real Oil pressure gauge Autometer
Morimoto XB LED fog lights from Panther Lights
Headlight bulbs GTR Lighting Ultra 2.0 from Panther Lights
TCI Trans. Pan
Aeromotive 340 fuel pump
I've done it with several of my cars....I jumpered a wire from the High beam relay back to the Fog light relay, which normally loses power when the High beams are activated.
BTW: For brighter lighting....check out Headlight Revolution:
https://www.headlightrevolution.com/...SAAEgLQlfD_BwE
They test all the bulbs that they sell to assure proper beam pattern, no hot spots, no blinding glare...etc.
I upgraded my 2020 Ranger STX with new LEDs for my Low beam, High Beam and Fog lights....and the difference was incredible!
Now, when some idiot in their Honda/Turdyota/Lexus drives towards me with their High beams on, I melt their retinas with the LEDs......
It's legally mandated to turn off the fog lights (ie. near-visibility lighting) when enabling the high beams (far-visibility lighting). Modifying your car to disable this feature would be illegal.
The reason for this is pretty simple - fog lights light up the near field in front of the car, sending a lot of light back to the driver, which causes your pupils to close somewhat, reducing your night vision. If you're commanding high-beams, you're indicating your desire to see farther down the road, for which you want maximum night vision. So, while you might see more of what's near to the car, you'll see less of what's down the road.
It's a bit like turning on the interior lights - after shutting them off, you need a few minutes to see fully again.
More light doesn't always mean you'll see better.
It is Illegal to go over speed limit, Illegal for certain lights being put in vehicles, illegal to remove catalytic converters, now in NY illegal for loud exhaust and so on, but yet it is done. I just like the lights to stay on. Where I drive the car mostly in NYC I don't have to worry about fog much. If you go on Daniel Stern lighting a lot of good info there on Lighting and legal/illegal about lighting, good reads and he gets very technical when responds to you.
K&N Cold Air Intake
TCI Trans. Pan
K&N Cold Air Intake
TCI Trans. Pan
In addition to (NickT02LS's) aesthetics...SilverPhoenix... why do you want the fogs to stay on when high beams are on?
It is often referred to as the bambi mod'. meaning: Provides additional lighting in rural areas where deer (here called, high speed beef) crossing/on the roadway in the dark are an issue.
^^^^^THIS^^^^^
When high beams are on the light projection leaves the left and right fields in the dark so you can't see the friken' animals/people that are running/jumping in front of you from the side which is why it should be ILLEGAL to disable the blasted things when the high beams are on!
WLB
#2912 of 7093
Conceived 8/6/2002
Delivered 9/19/2002
Adopted 8/10/2011
Pioneer 6x8 Front
Legacy 600w 6x9 Rears
JL 6.5 SubWoofer
DR Deep Aluminum Trans Pan
Mo's Dyno Tune
Gorilla Nuts - The System
WLB
#2912 of 7093
Conceived 8/6/2002
Delivered 9/19/2002
Adopted 8/10/2011
Pioneer 6x8 Front
JL 6.5 SubWoofer
Mo's Dyno Tune
Aesthetically speaking I can’t stand them turning off myself. More light the merrier IMO. In rural areas I run my light bar on my truck. Sure I don’t need to see 100’ up in the trees but having literally EVERYTHING surrounding the front lit up from side to side and ground to sky I can see every critter contemplating making a move.
Of course I can’t stand all these new cars that kill the driving light while activating the turn signal. I understand the why, just looks dumb.
People break the law usually to gain an advantage in some way or another.
Why would you break the law while disadvantaging yourself?
I'm glad you mentioned Daniel Stern. He goes into great detail why fog lights make you feel better but actually reduce your safety when used incorrectly:
https://www.danielsternlighting.com/...fog_lamps.html
Too many folks on this site are all about the feels, it seems.
I find it puzzling seeing someone getting bashed for asking a simple question. Then further ridiculed when when not in agreement. Thank god congress hasn't amended freedom of speech.
