As others have posted, I like having my foglights on all the time because of the wide and lower field of lighting.
i.e. The sides of the road, close to you, are lit up.
I've avoided multiple animal impacts because my foglights lit up the animals on the shoulder of the road.
Pretty amazing isn't it, but as you can see I will give my opinion, and being well aware of legalities and lighting as mentioned in Daniel Sterns website I am confident in my decision to have em on.
Hey could have been worse, I could have said I was using HID's in non HID's housings
2003 Marauder Purchased Feb. 2021 from original owner 62,000 miles
Cylinder Head Cooling Mod from Marty
K&N Cold Air Intake
SCT 4 with custom Tune
Stainless Works Cat Back exhaust with Magnaflow 10416 mufflers
4:10 gears with Cobra Carbon posi disc and Ford Girdle cover
Real Oil pressure gauge Autometer
Morimoto XB LED fog lights from Panther Lights
Headlight bulbs GTR Lighting Ultra 2.0 from Panther Lights
TCI Trans. Pan
Aeromotive 340 fuel pump
