Unless your e brake is saturated in gear lube and already garbage then you do not have to remove any of it. This will save you a good deal of time. Just rotate the axle slightly to avoid hitting the backside of the wheel studs on anything and it will go in plenty far enough to remove the C clip easily with just a magnet.
