Results 1 to 15 of 16
Thread: Engine cowling above firewall
    Oct 2020
    Chandler Arizona
    Hey Guys,
    This cowling, is part # 6W7Z5402228AA
    looks to be discontinued. I'd like to replace mine.
    I think the crown vic and the grand marquis (03/04) might be the same?
    If so, I could probably get one from a junk yard.
    Does anyone know if they are the same, or where I could get a new one, or a used one that is in good shape?
    Thanks
    -KK
    May 2019
    Harrisburg, NC
    I was looking for info in regards to the MM's windshield and happened across this:
    https://thepartsfarm.com/products/20...vent-panel-oem
    May 2009
    Moreau Island
    I replaced one of ours and had to adjust the wiper fluid hoses. Since it was different, I guessed it was a Marquis panel. If you go to a junkyard make sure the screw holes on the passenger side are not broken.
    Lehigh Valley, PA
    In 06 they slightly revised the wiper cowl, I believe that part is still available from Ford. Blackened300A put one on his car and noted that he had to re-route the washer hose.
    2063/3214
    5377/7838
    Oct 2020
    Chandler Arizona
    Quote Originally Posted by SilverPhoenix View Post
    I saw that one. Pretty beat up. Thanks though!
    Apr 2010
    South Florida
    I have one that's in good condition. They all seem to break on the passenger corner tho. Lmk
    Sep 2008
    USA
    I have one as well, but need to put eyes on it. It's in a different garage that i haven't been to in a while. Pretty sure the corner is not broken
    Ex Panther Owner
    Jun 2008
    Waukesha, WI
    Buy a new one. It makes the underhood look a lot cleaner. I just replaced mine and it made a big difference. I had an NOS one.
    The Dirty South
    ^^Not an option, the cowl cover is discontinued for all CV, GMQ, and MM
    Oct 2020
    Chandler Arizona
    NOS = new old stock?
    Jun 2008
    Waukesha, WI
    Too bad. I didn't know.
    Jun 2008
    Waukesha, WI
    Yes.......
    Lehigh Valley, PA
    Well that sucks, I just went and checked on Tousley and you're 100% right.
    Guess I better always remember to pull that one screw in the left corner and not crack the corner off.
    2063/3214
    5377/7838
    Apr 2010
    South Florida
    Vibration causes it to crack, I would go loosen Yours a bit.
    Sep 2005
    APPLE VALLEY,CA
    I see a number of them on Ebay sold by LKQ. Just order a can of satin black paint, or Charcoal (matches the interior of the Marauder)
    and repaint it. Personally, I'll look at Pick a part for it next time I go.
  1. Firewall tag
    By deadeyecop1 in forum The Classic Lounge
    Last Post: 02-24-2015, 10:18 PM
  2. Firewall Question
    By Dragcity in forum Community Discussion
    Last Post: 12-28-2006, 12:28 PM
  3. Firewall Holes???
    Last Post: 11-17-2005, 06:08 AM
  4. punch thru firewall
    By LVMarauder in forum Shop Talk
    Last Post: 03-12-2005, 03:50 PM
  5. Gauge wiring through firewall
    Last Post: 08-02-2004, 11:04 AM
