Results 1 to 15 of 18
Thread: mmr cross cylinder head cooling mod
    Oct 2020
    Chandler Arizona
    Hey Guys,
    I bought this kit from mmr that taps into the freeze plug holes that face straight up at the left rear and right rear of cylinder heads.
    Coolant is leaking slowly from the black 1-inch ferrule on the elbow, passenger side.
    Anyone run into this problem before?
    I thought I would ask before I start taking stuff apart in order to get in there with a big wrench....the kit is pictured below.
    Thanks
    '03 Silver Birch. Stock rebuilt 4.L 32V DOHC, V7-JT blower w/ADTR racing supercharger kit, Shift kit in transmission, stainless works long pipes and cat backs, Ridetech coil-overs front, shocks in back (ADTR kit). OEM Mercury wheels, drop down mattress for under car comfort. ECD for start up (rev15a) 5/15/21.
    Oct 2005
    Southwest Florida, Lee County
    Does it say anywhere to use thread tape or sealant? I mean, even if not it's not a bad idea to double up.
    '04 Silver Marauder w/ sunroof - HID lighting, JL Audio / Eclipse DVD/NAV/iPod/camera, 4.10's, 2" drop, Progard Bumper Baffle, Delete tips, Billet Pedals, BC4E dead pedal, Lidio Tune, Mach1 chin spoiler, K&N CAI, TCE SS lines, Super40's, tinted tails, SS Inserts, Heinous Control Arms, Real oil gauge, Steeda UDP, lighted door handles. Just about ready for EATON SWAP!
    2004 Mercury Marauder
    2,187 of 3,214
    997 in Silver Birch
    448 with light flint interior
    304 with heated seats
    336 with sunroof
    The Dirty South
    ^^^No need with -AN fittings
    Sep 2008
    USA
    That looks like push-lock hose?
    Could be leaking at the hose
    Ex Panther Owner
    Oct 2020
    Chandler Arizona
    Massacre,
    the hoses attach over a barb and a hose clamp is used.
    The leak is from the female ferrule.
    I'm going to get a 1 inch crowfoot and tighten those down just a bit - hopefully this will keep me from having to take other stuff off.
    The Dirty South
    Quote Originally Posted by massacre View Post
    Rob, how ya been? Good to see your still around.
    Your correct push lock not "barb" as the OP stated. Wonder if he used a push lock tool to install the fittings?
    Massacre,
    What happens when you tie 2 dead ends together? You end up with a dead end.
    I don't see how MMR can advertise this as a "cooling mod". You will need an outlet for it to work as intended.
    Oct 2020
    Chandler Arizona
    Hey guys..
    the photo I attached above is from the mmr website.
    When I saw the comment from musclemerc above, I went out and had another look.
    It turns out the two 90 degree connectors are different from one another.
    See below photos
    the left photo is the connector I had a hose clamp on (removed for this photo)
    the right photo definitely shows a different connector - perhaps the push lock type mentioned above.
    In any case...the leak is not coming from the hose to 90 degree elbow connection.
    As far as MMR goes - I am still waiting for them to impress me. :/
    Internal block heater mod?
    Jun 2008
    Waukesha, WI
    You can try slightly turning the big nut. If it still leaks I would take it off and check the mating tapers. If there are any scratches or corrosion try cleaning them up with a red scotch brite pad.
    The Dirty South
    Hey guys..
    See below photos
    Just an FYI both of those are push lock fittings and you put a hose clamp on one not realizing you lost the stop ring that is present on the other fitting. The clamped hose will fail sooner or later (look at the pic its already cracked the long way).
    I would back up, drink a cold beer and realize it all has to be removed and reengineered.
    You got a little ambitious with the grinder on your lower intake. Ouch!
    Oct 2020
    Chandler Arizona
    Thanks for the input. I think.
    The Dirty South
    Your welcome. I think.
    Sep 2008
    USA
    Good to see you too Travis!
    I agree, needs to be re-engineered. I have never been a fan of MMR cooling mod parts.
    If it were me i would get some real AN fittings and hose and make new lines.
    Edited to add:
    On my cars i take the hottest coolant from driver's side head, and send it directly to the radiator to be cooled.
    Travis is right, that MMR setup doesn't efficiently move the coolant in the proper way.
    Ex Panther Owner
    Oct 2020
    Chandler Arizona
    Yes, I agree. Not optimized for sure.
    Marty thinks there is a better way as well.
    Thanks again.
    The Dirty South
    ^^^ I'm a firm believer in doing a whole lot of research before tearing into a project, then asking for help after the damage is done. This forum has a lot of talent, it doesn't hurt to ask beforehand.
    Here is a thread I wrote years ago when cooling mods weren't offered by vendors, and when they did, they offered 1/2" stuff which is way too small to be effective.
    My 5/8" Cooling Mod | TCG | The Chicago Garage
    We took it on ourselves and figured things out on our own utilizing backyard engineering. Siege takes credit for the current (and best) way to route the flow.
    I personally use a Cobra Engineering rear cooling mod with Siege's routing method.
    Disclaimer: this information is NOT a for sale ad nor is it intended to serve as such.
  1. Cooling mod for rear of cylinder head
    By NickT02LS in forum Shop Talk
    Last Post: 11-20-2021, 11:59 AM
  2. Rear cylinder cooling mod cheep & tidy
    By MCAT in forum Shop Talk
    Last Post: 01-17-2019, 10:38 AM
  3. Wanted To Buy In Need of a new cylinder head
    By marauder'10 in forum Marauder Parts/Misc. Wanted
    Last Post: 05-09-2012, 04:57 PM
  4. For Sale In Need of a new cylinder head
    By marauder'10 in forum Marauder-specific Parts for Sale
    Last Post: 05-09-2012, 02:49 PM
  5. For Sale 03 mm left cylinder head.
    By ktt in forum Marauder-specific Parts for Sale
    Last Post: 02-01-2012, 10:09 PM
