Results 1 to 13 of 13
Thread: Intake cleaning...
    Dec 2021
    Cape Coral, Fl
    Intake cleaning...
    Any good cleaning suggestions while I'm cleaning the injectors?
    Sent from my SM-G950U using Tapatalk
    The Dirty South
    Remove the intake, get 3 cans of brake cleaner, and go to town.
    Go through a can, brush, then rinse with lot of water, repeat till clean.
    Install new upper/lower gaskets (the EGR already burned through the upper)
    Cleaned way too many of these over the years!
    Just going off of his pic and your great suggestions as usual I feel the need to simply add in “Remove upper and lower intake”.
    Or what a mess that would be!
    The Dirty South
    I started with that step.
    I agree, that would be a mess and probably a blown engine afterwards if he doesn't remove the intake manifold
    OP, the question I have for you is what are you going to do to prevent it from happening again?
    I'm willing to bet you have a pretty good puddle in the base. Thick puddle!
    Dec 2021
    Cape Coral, Fl
    Obviously an oil separator is needed. Who still makes ones that fit Marauders?
    The Dirty South
    New PCV valve, and the best catch can (something bigger than a pill bottle) I could find
    Draft42 design may still be in business?
    Jun 2008
    Waukesha, WI
    I agree with Travis. Remove and clean. I use a Mishimoto catch can on my PCV. Works great!
    Dec 2021
    Cape Coral, Fl
    Got it.
    Jun 2008
    Waukesha, WI
    This is the exact one I have. You can mount it to the pass inner fender just above the strut. I take a cap from a spray paint can and put it under the drain valve to empty.
    https://www.mishimoto.com/compact-ba...2-port-bc.html
    Dec 2021
    Cape Coral, Fl
    With no more brake parts cleaner on hand, the good Lord reminded me that I have plenty of lacquer thinner and easy off oven cleaner... So with that, a West Virginia toothbrush, and sime elbow grease it cleaned up quite well.
    Dec 2021
    Cape Coral, Fl
    now, can anybody point me in the direction of torque specs and tightening sequence of the upper and lower intake?
    Jun 2007
    Bethlehem, PA
    I posted it on FB, I'm pretty sure you asked yesterday.
    2003 DBP # 153 Whipple 3.4 in coming soon
    2004 Black Trilogy #43
    Dec 2021
    Cape Coral, Fl
    Yep, got em.... I always check here first since theres usually more accurate knowledge here, then to outside sources.
  1. Gas, additives and intake/injector cleaning
    By sflrainmaker01 in forum Shop Talk
    Last Post: 04-20-2013, 10:09 AM
  2. Replies: 5
    Last Post: 01-31-2011, 11:13 AM
  3. Intake gasket cleaning info
    By FordNut in forum Shop Talk
    Last Post: 08-07-2008, 11:16 AM
  4. Cold air intake filter cleaning
    By freakstatus in forum Shop Talk
    Last Post: 12-22-2007, 09:47 PM
  5. cleaning upper intake manifold
    By Local Boy in forum Shop Talk
    Last Post: 10-10-2007, 03:10 PM
