Double DIN will fit nicely in these and as an ex installer of 19 years I have some tips regardless of the brand. When making the connections you CAN use the OE woofer and it will sound much better if using the subwoofer controls on the new radio. Also, set the crossover roll off point to ~100Hz and 12dB/octave. If using deck power on the 4 speakers, utilize crossover points if available. Use a 5 volt adapter to trigger the OE amplifier or use a suitable resistor to prevent on/off pop. The illumination wire in the harness (blue/red) will only show 12 volts if you cover the sunload sensor on the dash. The speed pulse wire for navigation is on the harness, too. It is gray/black.
2004 Mercury Marauder
2,187 of 3,214
997 in Silver Birch
448 with light flint interior
304 with heated seats
336 with sunroof
