Results 1 to 8 of 8
Thread: blow motor fan only goes on high
    Jun 2010
    Boston
    My marauder's blower motor only goes on high... is that the resistor mounted on the firewall which replaced twice already?
    May 2019
    Harrisburg, NC
    Most likely. Mine was doing the same; replaced it 2 months ago.
    Jun 2010
    Boston
    Thanks.. i replaced it out 2 years ago with a Ford part too... geez....
    I can repair yours. PM me.
    Aug 2004
    S.E. of Cleveland
    I have a theory on why these burn out, but need to ask a question. Do you use Max AC with fan set to less than HI? I suspect the transistor is not getting cool outside air across it, per hvac diagrams, thus it is overheating. When normal AC is selected, outside air is flowing across the transistor.
    ______________________________ _______________
    2003 BLACK 300A 06/19/2002 Build 1665 of 7839
    May 2019
    Harrisburg, NC
    I've heard that the failure is caused by poor quality solder being used at the solder points...
    Jul 2002
    Marietta, GA
    Mine was Solder joints, resoldered with better solder and lasted until I sold the vehicle. That is the repair that Jim uses most of the time.
    Bill
    03 Mercury Marauder, 300A
    SOLD
    2005 Lincoln Town Car, ADTR Supercharger, TCE Brake Lines, MO's Tune
    2020 Lincoln Aviator Reserve
    Quote Originally Posted by Black Terror View Post
    I use solder containing lead. The solder used in OEM units has to be RoHS certified which means it has no lead in it. Lead is what makes the joints flexible and not prone to crack or fail. I also add a copper wire at a certain connection.
  1. Blower motor stuck on high
    By minimarine09 in forum Interior Electrical/Electronics
    Last Post: 07-05-2018, 03:55 PM
  2. I.A.C. Motor RPM too High?
    By VCobraV in forum Shop Talk
    Last Post: 12-29-2011, 11:16 AM
  3. a/c and vent only blow hot air
    By dankwun in forum Shop Talk
    Last Post: 01-28-2011, 02:30 PM
  4. Fan don't blow...
    By 1of327 in forum Shop Talk
    Last Post: 06-02-2009, 11:27 PM
  5. High Speed High Frequency Noise
    By engine23ccvfd in forum Community Discussion
    Last Post: 07-25-2003, 10:06 AM
