Page 1 of 3 123 LastLast
Results 1 to 15 of 35
Thread: Newbie with a problem
    Jun 2022
    Brockton MA
    Hello all. I recently joined to learn more about my 03 Marauder. I didn't think I would need help so soon. The story: When my father passed away 12 years ago I inherited his 64 thousand mile Merc. I drove it to my home and parked it in a heated garage. Time flies and now I am ready to drive it. The gas was old so before starting, I removed tank and replaced fuel pump. Gas was slightly yellow but still smelled ok. Used the 10 gallons in lawn mower. New fuel filter and pressure check showed about 60psi. Cranks strong but not a hint of firing. I have some mechanical ability but these Fords are all Greek to me. I am thinking a spark problem or the injectors not getting signal? No codes present. Thank you for any input.
    Jun 2022
    Brockton MA
    update: she started on a shot of starting fluid and ran for a few seconds, so it is a fuel problem.
    Does the fuel pump prime (it's audible) when you turn key to "on" but not crank. I would change fuel filter too with 12 year old gas..prolly gummed up inside
    Wisconsin
    Check the inertia crash reset button to see if it got tripped somehow.
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
    Dec 2021
    Cape Coral, Fl
    The inertia switch is in the trunk on the drivers side in case you were not aware. Check that... then fuel pump relay and fuse.
    Sent from somewhere near my Marauder using Tapatalk
    Wisconsin
    Quote Originally Posted by svtmerc View Post
    With sitting that long, could very well be the relay. Tap on it or swap with another like horn or something after confirming it is working.
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    JL 6.5 SubWoofer
    Mo's Dyno Tune
    Dec 2021
    Cape Coral, Fl
    Also... anybody think the FPDM? I don't know how often those become an issue.
    Wisconsin
    Could be, anything is possible especially with electronics. But given it worked when 1st parked, it wouldn't be on my list of 1st things to check.
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    JL 6.5 SubWoofer
    Mo's Dyno Tune
    Jun 2022
    Brockton MA
    I have a new filter installed. Fuel pressure was close to 60 at the schrader valve left front of fuel rail.
    Jun 2022
    Brockton MA
    Fuel pump can be heard when key is turned on so power is there. I was thinking noid lights on an injector or is there another way to test for power there? I can't believe all 8 injectors are plugged. I have a ford manual which seems useless. I will try to find what fuel pressure is supposed to be.
    Dec 2021
    Cape Coral, Fl
    Here are the pressure specs. from Chiltons.
    So it looks like your pressure is good.
    Dec 2021
    Cape Coral, Fl
    I'd say trace the injector harness, make sure a rodent didn't chew into it.
    Sep 2005
    APPLE VALLEY,CA
    Sounds like the fuel pump might be bad. (yes, the new one)
    Jun 2022
    Brockton MA
    thank you!
    Jun 2022
    Brockton MA
    It wouldn't be the first time a new part failed.
  1. Newbie
    By paulie in forum Welcome Forum
    Last Post: 02-22-2016, 09:59 PM
  2. Met a newbie
    By Bradley G in forum Drag Racing Round-up
    Last Post: 08-09-2009, 08:00 AM
  3. Newbie
    By Budman in forum Sunshine State Marauders
    Last Post: 12-03-2005, 04:46 PM
  4. newbie
    By earlystroke in forum Community Discussion
    Last Post: 09-13-2004, 04:51 AM
