Results 1 to 10 of 10
Thread: Water Temperature gauge question
    May 2022
    Los Angeles Califoirnia
    So I finally got to drive my MM in Oregon today…very happy! Question on coolant temperature - outside temp today is 90 plus, AC on full, temp gauge sits right above half. On the freeway, doing 65 mph, it rose to about 3/4 or slightly more, and then proceeded to drop again after a few minutes. Is this the fan coming on? Coolant was replaced by the Ford dealer here in Beaverton a couple of weeks ago.
    Is this about normal on a hot day?
    Thanks
    Feb 2006
    Rosemount, MN
    My guess is there is air in the system after then coolant change.
    Jun 2008
    Waukesha, WI
    Follow this procedure to burp coolant system
    https://www.reischeperformance.com/refill.html
    Oct 2004
    My coolant temp gauge after warm up stays at just a hair over half. As engine temps rise the auxiliary fan should turn on via temp sensor. As mentioned check system for air in system.
    May 2022
    Here is the update - system was checked for air, and it was OK. Temp was still rising, so fan operation was checked and it was running at 98%, so that was good. Tech thinks its a defective thermostat, that is sticking, and not opening all the way at times. New thermostat goes in tomorrow, so we shall see! Thanks for your suggestions.
    Installed the Marty Tune, and its awesome!
    TALALA OK.
    Easy to get the wrong one from the parts store. Original Motorcraft is RT-1110 188 degree. Stant 14138 is 180 degree.
    03 BLK 9K M.
    07 GT500 13K M.
    98 MARK VIII 75K M. BOUGHT NEW
    21 EXPLORER PLATINUM 3.0
    18 GENESIS G80 5.0
    54 GMC
    ....Napa 109
    May 2022
    Thanks, yes have confirmed the part number with the shop…
    May 2022
    The cooling system blues continue….while the car was on the rack, it was noticed that the radiator has a pinhole leak, that seems to spray coolant when under pressure, so a new radiator is being installed!
    Wisconsin
    Classic symptoms of radiator restricted due to bugs/gunk. Pull shroud and flush/clean radiator fins with gentle pressure - not full blast pressure washer pressure. Clean the radiator and a/c condenser and then try the highway again. Good luck!
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
  1. For Sale AutoMeter Oil Temperature Gauge
    By MyBlackBeasts in forum Other Parts for Sale
    Last Post: 12-22-2020, 07:09 PM
  2. Temperature gauge
    By B4Real in forum Shop Talk
    Last Post: 03-29-2019, 10:57 AM
  3. Temperature gauge and mph
    By jstevens in forum Community Discussion
    Last Post: 01-27-2012, 10:22 PM
  4. temperature gauge
    By patt7 in forum Shop Talk
    Last Post: 10-12-2010, 05:06 AM
  5. Temperature Gauge
    By Marc in forum Shop Talk
    Last Post: 02-06-2004, 07:26 AM
