Results 1 to 2 of 2
Thread: Installed Whipple Supercharger But..... Having some issues and need your help....!!!
    May 2013
    Saudi Arabia
    Unhappy Installed Whipple Supercharger But..... Having some issues and need your help....!!!
    Hi
    It's been a while and I hope everybody is allright ! So I was working with my brother on the Marauder and we finished rebuilding the entire engine and putting the Whipple with everything together (Thanks to you gents and this awesome forum).
    However, When we crank it for the first time we notice the RPM Is always High (Like 4000 rpm+) The throttle position is close ! But the RPM Is not getting any less than that !
    I tried and checked the Whipple bypass actuator Valve and its functioning OK. And it's getting lower a bit only if I disconnect ALL The whipple vacuum lines !
    So my question, Is this normal since the car need to be programmed first before cranking ?
    Need your help gentlemen, As I'm sure I'm going to face issues in start-up ! But I have big faith in you gentlemen !
    I well post pics soon.
    Eaton M112 Supercharger
    Intercooler
    Lower intake plenum
    Coolant Intake Manifold
    TB Intake Plenum
    Throttle Body
    Cobra air intake tube
    Accelerator cable bracket
    Fuel rails
    39lb. injectors
    Cobra heat exchanger
    lower Metco pulley with hub
    Intercooler reservoir
    90mm Lightning MAF
    MAF to filter adapter plate
    Conical air filter
    Custom Gortch Brackets
    Heat Exchanger brackets
    Intercooler pump
    Intercooler pump bracket
    Ribbed idler pulley
    Belt tensioner
    Alternator Pulley
    Fuel Pump
    EGR delete kit
    New accessory belt
    Cooling tube
    IAT sensor
    You need a tune for start up
  1. For Sale Not mine--> Whipple 2.9 supercharger
    By Mebot in forum Other Parts for Sale
    Last Post: 05-11-2013, 01:42 PM
  2. For Sale Whipple Supercharger pulleys
    By Michael in forum Marauder-specific Parts for Sale
    Last Post: 01-21-2013, 05:11 PM
  3. For Sale WHIPPLE supercharger decals
    By F8LBITEva in forum Misc for Sale
    Last Post: 12-05-2011, 06:16 PM
Tags for this Thread
