Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Fuel Vapor Tube with Service Port
  1. #16
    Washington State
    Quote Originally Posted by BAD MERC View Post
    What is P/N on the blue and white Ford label?
  2. #17
    San Angelo, Tx
    I sold my 339k Marauder year and half ago bought a 17k Marauder to replace it. Old one had a CG hood and i found a replacement lift strut but i want to try the way you did yours.
    Which lift and how did you decide to mount the lift pivot on fender. Thank you.
  3. #18
    I believe the mock up set came off a junked 2000ish Dodge Intrepid or 300. I believe even the stratus is the same but went for the largest hood. Worked great so I ordered a new set of them as the free struts were worn.
    I reused the hood location as is and drilled a 1/4” hole on the fender lips for the new lower mount, basically mimicking the fender mount holes, then installed vertically. I shaved just a tad off two sides of the washer to fit in the fender lip.
    I remember the drivers side I had to remove the vacuum storage box to get the nut on the Dodge mount as it was in the way. Then I just mounted it back up was installed.
    Placement is everything. Too far forward to achieve factory hood height and they won’t hold up the heavy hood at that angle. Use a C clamp as a stop to find the sweet place. The hood will sit a lot higher up but that’s better for us tall folks. I didn’t even remove the hood on the last engine swap..
  4. #19
    San Angelo, Tx
    Thank you.
  1. Wanted To Buy Vapor return tube
    By william s in forum Other Parts/Misc. Wanted
    Last Post: 05-17-2016, 06:26 PM
  2. Wanted To Buy vapor return tube
    By william s in forum Marauder Parts/Misc. Wanted
    Last Post: 04-24-2016, 07:08 AM
  3. Service Port Dead
    By zrwhat in forum Shop Talk
    Last Post: 08-11-2009, 06:11 AM
  4. Service Port Not Working?
    Last Post: 08-01-2007, 05:01 PM
  5. replaceing fuel vapor canister (chebbie)
    By Bradley G in forum The Lounge
    Last Post: 09-13-2006, 09:15 AM
