Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
Thread: Blown engine. How did this happen?! I'm sad...
  1. #16
    Mar 2016
    Asheville, NC
    Actually I was wrong again. I found my title, I bought it in 2014, so about 11k a year. Still not good, I know... I f*ed up, what can I say? Good news is, it won't happen again !
  2. #17
    Sep 2021
    SunCity West AZ.
    Blog Entries
    1
    lighten up Francis
    2003, 2nd owner, Shiny new to me 60K, all original, Black Beauty,
  3. #18
    Sep 2008
    USA
    If i had to spend $8k on a 4.6, i'd spend the extra $$$ and go with a coyote. I'm interested in how the rod bearing diagnosis was done, was the engine removed?
    Ex Panther Owner
  4. #19
    Where is he getting a crate 4.6 DOHC at?. Jasper doesn't show any and it's not a motor that is made into a crate unless building a race or high hp motor. You are looking at $6-7k to rebuild what you have at min.
  5. #20
    Mar 2016
    Asheville, NC
    They did not remove the engine. Maybe just used a screw driver? They seem confident its in the low end, but it doesnt sound like the low end to me.
    The price tag keeps increasing as a crate is becoming less and less likely. Im looking at close to 10 Gs with shipping, now.
  6. #21
    LS swap. Done.
  7. #22
    Sep 2008
    USA
    LS swap. Done.
    Def cheaper than Coyote lol
    Ex Panther Owner
  8. #23
    Jan 2006
    Northern California
    If you can live without the car for quite a while. Send it to Dallas,GA..MO's Speed Shop..Marty Ochs. He doesn't frequent here, but is the go to shop for Marauder. They know them inside and out. Mine has been there twice and I'm 680 miles away.
    I sent my baby to MOs from California. Best decision in my adult life!
  9. #24
    Lehigh Valley, PA
    How many miles are on your car? (Edit: just saw on page 1 you're around 160k) Unless its some low mile mint show piece (which I kind of doubt), just find an aviator or mach 1 automatic motor and plunk it in there. I bought a 137k mile 03A on this site with a blown motor (spun rod bearing from blowing 4 quarts of oil out the dipstick tube due to an improperly installed lokar dipstick), dropped in a 130k mile 03 Aviator engine I bought from a JY on ebay for 1800 bucks, did the swaparoo and drove that car to 183k miles before selling it to another member on here. Its still on the road with over 190k on it now.
    I actually do have a friend in PA with a Marauder engine he's looking to sell cheap if you're willing to trek up here and pick up.
    2063/3214
    5377/7838
  10. #25
    Winston Salem, NC
    Because of Marty's proficiency with these cars, it is still in your best interest to ship her up there. We have other friends in the game (Chris Curless in Michigan) who is also a master in these regards, but it is a bit further from Austin than Dallas, GA.
    2003 300A
    Eaton Swapped by Curless
    Brake Upgrade
    Mo's Tune
    JLT Intake
    Addco Sway Bars
    ADTR Coil Over Suspension
    SW Headers and Exhaust
    Accessories By FastBlackMerc
    4.10 Gears
    Aeroforce Gauges
    Pantherlights Headlamps
  11. #26
    Aug 2012
    Kansas City
    You have to check the oil on these engines frequently. My wife's 84K mile car uses around 2 quarts in 3000 miles, while my 190K mile junk yard Aviator engine car uses NONE. I would throw a bottle of Lucas or STP additive in it to see if it quiets down for fun (doubtful) and drive the SOB until it lets go. I would also start searching your local junk yard for 03-05 Aviators. Good luck, sorry to hear.
    Neil
    2003 Mercury Marauder - SB/LF
  12. #27
    Jun 2017
    Oxford, PA
    You never told us what grade of oil you were using and what the oil pressure is at hot idle if you have a real gauge.
    At this point won't hurt to run 5w 30, or 10w 30 or rotella 15w 40 if you get low readings. start with 5w 30 and see if the noises die down....
    2003 300A BLK/DC
    153K : runs like a swiss watch...
    395/7838
  13. #28
    Sep 2005
    Buffalo, NY
    I moved to 5/30 Motorcraft oil with Motorcraft oil filters, always. Changed 2,000 to 4,000 miles, not time dependent.
    I am in the process of rebuilding mine. Teksid block is in the shop. Rotating assembly ordered. Trilogy going out to Steigemeir.
    I blew mine up due to user error. I freely admit it. old fuel, happy day turned expensive! I broke two rods, bent four more and two looked nearly normal. One piston was in three pieces and made quite a mess. No useable parts on that engine from the deck to pan plug.
    Anyway, I have the pistons, rods and crank out of that Teksid engine I got out of a 1997 Lincoln Mark VIII. They are available for sale if you need good internals, I am Going all forged in mine. The block needs only 0.010 over to clean up the ridge, so it was a good engine. Crank journals and bearing are not at all scored, mains and rods. Bearings are barely polished in few areas. I probably could have just dropped that engine in my Marauder and stuck my heads and supercharger on it and been good to go, on borrowed time.......
    Let me know if you need some good, cheap, used parts for getting back on the road. The labor part really stinks. These things are not easy to work on. I am NOT looking forward to putting mine back together again, and trying to stuff it back in the car.
    Built: 3/16/2004
    Must - Go - Faster !
  14. #29
    Jun 2007
    Whitehall, PA
    Am I that friend?
    2003 DBP/LF - # 36 (sold)
    2003 DBP/LF - # 205 (sold)
    2004 Black - Trilogy #43
    2003 Black - shitbox (sold)
    2004 DTR - shitbox #2
  1. Blown Engine
    By dkier81 in forum Shop Talk
    Last Post: 04-23-2015, 09:47 PM
  2. For Sale Blown Engine
    By Murked#2866 in forum Marauder-specific Parts for Sale
    Last Post: 06-23-2013, 07:44 AM
  3. Might've Blown Engine
    By Ktorres1 in forum Shop Talk
    Last Post: 12-24-2012, 09:32 AM
  4. 100K on blown engine?
    By Motorhead350 in forum Power Adders
    Last Post: 05-20-2010, 06:48 PM
  5. Blown Engine Confessional
    By Dan in forum Shop Talk
    Last Post: 05-13-2010, 11:53 AM
