Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
Thread: Boost problems - I should be getting more
  1. #16
    Jun 2008
    Waukesha, WI
    I’ve use 2 different BOV’s that were adjustable but never had to adjust them. I believe the adjustment is more for a turbo application where you’re trying to get the valve to open at a certain psi.
  2. #17
    Oct 2020
    Chandler Arizona
    Blazen,
    the MAF counter is the last thing boosted / cooled air goes by before getting into the manifold...so, downstream of the SC.
    Thanks for the thoughts on the root cause here. My trouble shooting list is now
    1) boost gauge correct confirmation/leak in line to gauge
    2) air pipe connection leaks
    3) belt slip..
    Looking into all of these could lead to a number of possible solutions.. many of which you and JB have mentioned. I'll be relocating to Phoenix pretty quick here as the summer golf gig is almost up. At that point I can really go at it.
  3. #18
    Jun 2008
    Waukesha, WI
    Good luck and keep us posted!
  4. #19
    Oct 2020
    Chandler Arizona
    Will do.
    FYI - called Vortech twice (!) this morning. The gentleman that helped was very clear that boost isnt going to open the BO valve, manifold vacuum only, so BO valve operation isn't the problem.
    We talked about getting more boost out of the V7. So far I have spun the V7 up to 40,000 rpm (engine speed 5.5K). It can go to 60,000. So, I could probably get it to 9 pounds if I'm willing to get up above 7000 rpm engine speed - which I think is higher than Marty had me go in the tune session.
    The other route is a SMALLER SC pulley, which will turn the SC more for the same engine speed. However, smaller diameter means more chance for slip. As you have suggested, he mentioned 8 rib. Sigh...that maybe where this winds up.
    Bunches of trade offs and risks in this business.
  5. #20
    Jun 2008
    Waukesha, WI
    I recommended a 3.6" S/C pulley and an 10% OD Innovators West Balancer, remember? That combo will spin your S/C a little faster and most likely eliminate any belt slip. Plus you'll have a really good balancer. I was taught a long time ago to buy the most expensive balancer you can afford. It's job is to protect your engine from dangerous harmonics. You have a lot of time and money into this project, why not protect it?
  6. #21
    Jun 2008
    Waukesha, WI
    On a side note, if you indeed have a 3.33 S/C pulley.......
    Crank pulley dia / SC pulley dia X SC Gear ratio (V7 is 3.61) x Engine rpm = S/C impeller RPM
    Ø6.5" / Ø3.33" X 3.61 x 5500 = 38,756 rpm
  7. #22
    Wow the gear ratio on that thing is tiny! I only ran a 4.4/8.0 pulley set up on the F1-A and we saw 20#s on 93 at only 5,700 and the wastegate was already starting to bleed off excess.
    Definitely look into a quality oversized lower at minimum. I went with ATI on mine. Summit carries a wide variety of different diameters for the 4.6.
  8. #23
    Jun 2008
    Waukesha, WI
    I got that ratio from some random website. I just checked Vortech's website and it's actually 3.45:1.
    Ø6.5" / Ø3.33" X 3.45 x 5500 = 37,038 rpm
  9. #24
    I’ve only had the one centri and I was just used to calculating 5.40:1
    Looking at Procharger’s site even the P1 is a 4.10:1
  10. #25
    Oct 2020
    Chandler Arizona
    Hmmm. Makes me wonder why Vortech built the V7 with the small(er) gear ratio.
    I'm using 6 & 9/16ths inches for the stock balancer diameter....couldn't find the exact spec anywhere. I wonder how this is measured? Outside of belt to outside of belt or top or rib to top of rib?, or?
    In any case, Vortech does have a nice blower speed calculator on their webpage..select blower & enter two pulley sizes and engine rpm.
    Thanks again guys...I will eventually prevail!
  11. #26
    Oct 2020
    Chandler Arizona
    oops. not balancer diameter, pulley diameter.
  12. #27
    Jun 2008
    Waukesha, WI
    The stock balancer is definitely 6.5" diameter. This is just for reference, at 6k engine rpm my D1X is spinning at 52,455 rpm and I have 14psi max boost if my tires don't spin.
  1. Wanted To Buy MM with boost
    By MMBLUE in forum Marauder Wanted
    Last Post: 12-07-2017, 12:15 PM
  2. Too much boost?
    By blazen71 in forum Shop Talk
    Last Post: 12-24-2008, 12:06 AM
  3. HELP boost Problems
    By lastdaze04 in forum Shop Talk
    Last Post: 01-28-2008, 07:31 PM
  4. ~Boost~ @ 0*!
    By Bradley G in forum Trilogy Motorsports
    Last Post: 02-02-2007, 10:23 AM
  5. Replies: 10
    Last Post: 10-10-2006, 06:57 PM
