Results 1 to 15 of 17
Thread: engine sounds like a an old Mercedes diesel
    Mar 2021
    houston texas
    I got an issue, my engine sounds like an 80's Mercedes diesel. not exactly sure what it is but im afraid its a valve issue, doesnt exactly sound like valve tick, it also gets quicker with higher rpm but it doesn't get louder, is fairly faint. i got oil pressure and its not overheating. has anyone experienced this before? not sure if im describing the sound enough
    2003 Mercury Marauder 300A ~117k miles
    1987 Ford Thunderbird Turbo Coupe ~100k miles
    May 2009
    Moreau Island
    Does it go away when the car heats up?
    Mar 2021
    houston texas
    No it doesn't, sounds the same from cold to warm. its kind of like a muffled tick but I hear it near the drivers side head area
    Maybe a bit more information will help. I swapped my heads to some 9 thread heads, but I used the hydraulic lifters from the old head because the new ones didn't have any spring to them. the old lifters or whatever you want to call them had 130k miles, I used the old rockers as well but did not touch the spring or valve
    Heads have a poor cooling passage at cylinder 8 which makes it run hotter over time and can cause issues with a bent valve or build up on valve. Not just Marauder but Cobra guys too. There is a head cooling mod out there but it won't fix it if already bad. Compression test on cyl. 8 can help determine. Not saying that is it, but it can't be ruled out either just yet.
    Mar 2021
    houston texas
    I did the cooling mod when I installed the new heads
    Sounds like a lash adjuster not pumping up.
    Mar 2021
    houston texas
    is there a certain brand of lash adjusters that people here recommend?
    Jun 2008
    Waukesha, WI
    Quote Originally Posted by DMANFROMNOWHERE View Post
    OEM. If it's a timing chain issue, plan to do a full timing chain replacement. It's a lot of work but can be done with the engine in the car.
    For reference:
    https://www.mercurymarauder.net/foru...des-Tensioners
    https://www.modularmotorsportsracing...roducts_id=168
    This is not necessary, but if you have OCD like I do, this flips the pass secondary tensioner so it tensions the chain on the correct side:
    https://www.modularmotorsportsracing...roducts_id=455
    Mar 2021
    houston texas
    I replaced the timing chain not too long ago, at around 115k miles I believe, I have 130k now, replaced heads and inspected timing chain and everything seemed fine so I reused it.
    where can I buy OEM lash adjusters? mmr sells some but idk if thats the best place. from what ive seen its all pretty marked up
    Tasca normally has decent prices.
    Mar 2021
    houston texas
    UPDATE: I found the issue. I know you're not supposed to swap parts until the issue is fixed but instead diagnose and replace only what is needed but I still went and bought the Hydraulic lash lifters. Wasn't it, but at least I got new parts on my new heads so it isn't that bad.
    The issue was the timing chain. I took apart the front and found that the passenger side chain was a bit loose. there was tension where the tensioner was but it was loose where the guide was. everything still looks brand new and undamaged but I have extra new parts so I'm going to replace those and reinstall the tensioner, hopefully better this time. I'm sure this will solve the issue but I will keep you all posted!
    This cars been down since April with a month or 2 of it finally working only to make a noise and be out of commission. I could've had a shop fix all of this by now but its all a learning process so no regrets
    That’s normal. Dumb design.
    Rotate the engine and you’ll see it tense up, then slap around depending on where the valves are.
    Mar 2021
    houston texas
    UPDATE: runs like new. I replaced the tensioner with another new OEM tensioner and it fixed the issue.
    Not exactly sure why this happened. it might be because the heads got resurfaced and thus the tensioner needed more tension?
    maybe I didn't install it right the first time? but if I didn't, why did the noise start happening months after everything was reassembled instead of right away?
    I had fresh oil and oil pressure.
    beats me, but if your car ever sounds like a 80s German diesel, might want to look into timing chain tension.
    Mar 2021
    houston texas
    not fixed, never mind... not only that but a bigger issue arose.
    Details?
  1. engine knock. sounds like bad news
    By Marauder108 in forum Shop Talk
    Last Post: 02-13-2011, 04:13 PM
  2. Weird sounds from the engine
    By justbob in forum Shop Talk
    Last Post: 02-14-2009, 09:12 PM
  3. engine whines and sounds supercharged
    By dankwun in forum Shop Talk
    Last Post: 08-19-2008, 11:25 AM
  4. Ticking, tapping, diesel sounding engine
    By 1 BAD 03 MM in forum Shop Talk
    Last Post: 04-01-2004, 09:11 AM
  5. World's largest diesel engine
    By Topher in forum The Lounge
    Last Post: 10-23-2003, 08:12 AM
