Results 1 to 15 of 17
Thread: Headlights out! Help
    May 2022
    Los Angeles Califoirnia
    Hi All
    Im on a road trip in my 2003 MM - noticed last night that both headlights are out. One fog light (right side) works.
    Tail lights, blinkers, side lights, brake lights all work (so am guessing the LCM as modified by FastBlackMerc is not the problem).
    Any thoughts on fuses, relays etc?
    Thank you
    May 2019
    Harrisburg, NC
    OEM or LEDs/HIDs? If OEM, sounds like a possible chaffed wire somewhere. If LEDs/HIDs, could be ballast issue.
    May 2022
    OEM…both headlights inop.
    Hit the bottom of the dashboard where your right knee resides. Probably the LCM.
    Jun 2008
    Waukesha, WI
    I love fixes like this ^^^^^^^^
    Lehigh Valley, PA
    ^this, and curious, does your flash to pass still work? If so, that does indeed sound like a LCM issue and normally you can give it a smack like justbob said to get it to come to life again. Many things on panthers can be "fixed" simply by hitting them.
    Since you state your LCM was modified though with the external relay, have you tried removing the relay and jumping the two wires (I'm guessing 30 & 87 but check the relay itself for a diagram) to see if your lights come back to life? It could just be a faulty relay which any parts store would have.
    2063/3214
    5377/7838
    May 2022
    Yes, headlight flasher still works
    Lehigh Valley, PA
    Quote Originally Posted by PVEPANTHER View Post
    then the headlight relay in your LCM is acting up
    2063/3214
    5377/7838
    May 2022
    Thanks all…when I tried the lights today they came on for maybe 3 seconds and then I could or get them to come on again. Since I have no night driving the next few days will look at it when I get back. Is it pretty easy to replace the relay? Anyone have a relay part number?
    Thanks
    Lehigh Valley, PA
    Thanks
    This is the process to repair it so it won't fail again
    https://www.crownvic.net/ubbthreads/...59835&page=all
    2063/3214
    5377/7838
    Apr 2016
    Lawrenceville, GA
    FastblackMerc (Jim Marton) can rebuild your LCM
    .He’s probably done hundreds of them over the years for members here.
    Black 2003 300A- built 9/07/02, # 4,675 of 7094. Trilogy #243, Installed and tuned by Mo's Speed Shop. K&N cold air intake, Aeromotive fuel pump, Kenne-Bell boost a pump, dual oil catch cans, cooling mod, complete Stainless Works long tube headers and exhaust system, Meg's non-resonated 3.5" exhaust tips , 4.10 gears. Zack & Jerry big brake conversion, TCE stainless brake lines, Ntto NT555-G2 tires;. Ridetech coilovers in front Ridetech adjustable shocks on rear air suspension. ADTR front & rear sway bars, Metco rear control arms, watts link and driveshaft loop, upgraded transmission , PTC 2800- 3000 stall torque converter, transmission cooler, driveshaft balanced, window tint, trunk spoiler, trunk organizer, SS rear bumper inserts. S55 tail lights, Red Line floor mats, Ford Escape Audiophile 6 CD Stereo, BC4E dead pedal. FBM satin aluminum pedals. Colex Supercharged Marauder emblems. Car Motorsports custom hood insulator.
    May 2022
    FastBlackMerc did the retrofit on the LCM a few months ago. I will reach out to him as well. Thanks
    May 2022
    Well in true Marauder style, lights started working today! I need to figure it out as it needs to be a reliable night driver!!
    Jun 2007
    Whitehall, PA
    I used to kick the LCM, but I've also had both low beams burn out within a day. My advice is to start with the most obvious thing, the bulbs.
    2003 DBP/LF - # 36 (sold)
    2003 DBP/LF - # 205 (sold)
    2004 Black - Trilogy #43
    2003 Black - shitbox (sold)
    2004 DTR - shitbox #2
    May 2022
    Sorted….removed the external relay from the LCM pushed the pins in and reseated it, and its all good now! Thanks to FastBlackMerc.
  1. Headlights went out!
    By Breadfan in forum Shop Talk
    Last Post: 06-10-2013, 03:08 PM
  2. Headlights
    By airjordan2k8 in forum Shop Talk
    Last Post: 03-08-2012, 12:19 PM
  3. New Headlights
    By mgmsleeper in forum Community Discussion
    Last Post: 03-03-2012, 07:03 PM
  4. Headlights
    By gdsqdcr in forum Shop Talk
    Last Post: 02-06-2012, 07:27 AM
  5. New Headlights....
    By Marauderjack in forum Community Discussion
    Last Post: 12-27-2011, 01:12 PM
