Results 1 to 2 of 2
Thread: Oil pump with cobra pick tube or stock pick up tube
    Jun 2020
    Los Angeles County, CA
    Since I will have to be doing a timing job and motor mounts soon, I want to see if I can upgrade the oiling system to hopefully prolong the life of the engine since I do a lot of short drives and I want the maximum amount of oil getting to the heads ASAP on start-up. Was thinking about getting the m-6600-d46 oil pump combo with the cobra pick up tube (15/16 inch tube) and pairing it with the moroso 20555 oil pan as well as using 0w-30 engine oil to boost the amount of oil getting up to the heads. It seems like the pick up tube has more of the screen area left open and will suck up more oil faster? Not looking into getting billet gears since I never rev the car hard. Was also looking into possibly getting the Ford gt (supercar) roller followers to increase oil pressure as well. What are your guys' thoughts on such a set up? And apparently the cobra tube would need a spacer to attach to the block?
    I was thinking that the larger pick-up tube would possibly suck the oil pan dry IF driven moderately hard hence the upgrade to a moroso pan.
    Happy Thanksgiving!
    2004 Mercury Marauder, Black
    2008 Crown Victoria P71, Silver
    2010 Crown Victoria P7B, Black
    2010 Crown Victoria P7B, White
    Jun 2020
    Meant to say the Ford gt (the super car) follower followers not gt500. The one with the different oiling hole size.
  1. MMR oil pick up tube compatible?
    By 376shovel in forum Shop Talk
    Last Post: 12-11-2017, 11:22 PM
  2. Oil pick up tube fyi
    By Serge in forum Shop Talk
    Last Post: 05-18-2016, 01:15 PM
  3. Wanted To Buy Marauder oil pan pick up tube
    By chief455 in forum Marauder Parts/Misc. Wanted
    Last Post: 06-27-2015, 01:41 AM
  4. Wanted To Buy Timing Cover and oil pick up tube
    By O's Fan Rich in forum Marauder Parts/Misc. Wanted
    Last Post: 03-08-2015, 04:10 PM
  5. Wanted To Buy timing cover, oil pan and pick up tube
    Last Post: 02-12-2015, 10:04 AM
