Results 1 to 4 of 4
Thread: LED bulb types
    Feb 2023
    El Paso
    LED bulb types
    Looking to upgrade all my lights to LEDs but I can't find any info on if we need CANBUS LEDs or regular LEDs. I've searched on here and can only find the bulb size info only. Not sure on which of these I should go with to avoid problems. Any help would be greatly appreciated
    May 2009
    Moreau Island
    PM FastBlackMerc he'll set you up with either the info or even the bulbs.
    May 2019
    Harrisburg, NC
    I bookmarked an old thread with info about upgrading to LEDs: https://www.mercurymarauder.net/foru...lb-sizes/page2
    The data you are most likely looking for:
    Actual bulb numbers:
    Headlight – 9007 (2)
    Fog Light - H1 (2)
    Rear Stop Light / Turn Signal – 3157 (4)
    High Mounted Stop Light – 912 (2)
    Front Map Light – 168 (194) (2)
    Rear Light (long overhead console) - 42mm Festoon (1)
    Glove Compartment – 168 (194) (1)
    License Plate – 168 (194)
    Trunk Light – 2122 Festoon
    Underhood Light – 906 (2)
    Parking Light - 3157NA (amber) (2)
    Vanity Mirror – 29, 30 or 31mm 6641 (4)
    Rear Reading Light – 45mm Festoon (2)
    Front Foot Well – 168 (194) (2)
    Reverse - 3156 (2)
    Last edited by fastblackmerc; 09-22-2020 at 07:43 AM. Reason: Added fog light number
    Jul 2003
    Yonkers NY
    I needed an upgraded electronic blinker attached to the LCM wiring. There is a thread here I believe. Used regular led bulbs. I did not change the CHMSL as regular LED bulbs in there caused the cruise to malfunction. Other LEDs with resistors would probably work fine. Also did not get around to the fogs. I suggest nice looking front corner bulbs as the white lenses make them clearly seen by all.
    2nd Fastblackmerc.
    Jay
  1. bulb types
    By SMF in forum Shop Talk
    Last Post: 08-10-2012, 03:00 PM
  2. Theres two types of people...
    By ssikpiyelnats in forum Community Discussion
    Last Post: 06-24-2012, 11:05 AM
  3. HID bulbs types - The Differences
    By fastblackmerc in forum Marauder Innovations
    Last Post: 01-16-2012, 12:49 PM
  4. we have 2 types?
    By blackhueys in forum Shop Talk
    Last Post: 05-17-2010, 05:56 AM
  5. Hey builder types...
    By duhtroll in forum The Lounge
    Last Post: 09-07-2008, 07:17 PM
