I’m new to this forum and any help would be appreciated. I just bought a 2003 Marauder with a rod knock. Wondering if anyone or knows anyone who has a good motor to replace mine. Thank you in advance.
A rod knock? Simple. Rebuild it with a forged crank and better rods and make a nice platform for power adders. Then, at least you know what's inside.
2004 Mercury Marauder
2,187 of 3,214
997 in Silver Birch
448 with light flint interior
304 with heated seats
336 with sunroof
Lots of people swap to an Aviator engine. You have to use the Marauder valve covers, intake, oil pan, oil pump pickup tube, wiring harness, exhaust, coolant tubes, probably alternator and maybe timing cover. Make sure and hold on to all of these pieces even if you get a replacement, they are Marauder specific, obsolete, and hard to find.
Send a PM to a member on here that goes by the username mustangeddie; he might be able to help you out.
Look into a performance shop that is a Jasper Dealer and replacing with Mustang Cobra. Keep the Marauder front cover, etc.
I have one in Allentown, PA
2003 DBP/LF - # 36 (sold)
2003 DBP/LF - # 205 (sold)
2004 Black - Trilogy #43
2003 Black - shitbox (sold)
2004 DTR - shitbox #2
Was there some legitimacy to this question? Can we imagine for a moment that some owners can actually count their balls twice and come up with the same number? To me, a used engine gamble is far less appealing than building the block with matching numbers and at least KNOWING what's inside. A rod knock is an easy fix. A rod through the side of the block - not so much.
2,187 of 3,214
997 in Silver Birch
336 with sunroof
